Thread: DigitalFX 4.0
  1. #3981
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    See the #2 post in this thread should fix that, for some updated skin files...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #3982
    Oct 2006
    Midlothian, VA
    *Facepalm*. Holy crap I remember that now... Thanks so much blue. I fixed this very issue before and can't believe I completely forgot about it.
  3. #3983
    May 2009
    Bottom buttons (power, play, rr, ff, vol-, vol+) show up as numbers
    I just upgraded to the latest release of Riderunner and DFX 4 and am having some problems. The buttons on the bottom (power, play, rr, ff, and volume) just show up as numbers 0-7. Everything was working on RR9-22-09 and DFX4, but since RR10-09 and DFX 4 this showed up. I tried removing RR + DFX, even deleted the directories and registry entries. 2 Installs and its doing the same thing. Any suggestions?
  4. #3984
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    for some reason missing this file, remove the (.txt) and stick it in your fonts folder inside windows.
    **C:\Windows\Fonts
    Attached Files Attached Files
    Did it.. Done it... now I got to keep the neighbors kids away!!
  5. #3985
    May 2009
    Thanks! it worked great. I had the file, but deleted it and replaced with the one you posted. Everything is back to normal.
    Thanks again
  6. #3986
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Also FYI check 2nd post of this thread, (not a Dig) but many users seem to skip the troubleshooter in 2nd post of this thread,
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  7. #3987
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    So is the help file, but not too many look in there either.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #3988
    Mar 2007
    Atlanta, GA
    This is a minor issue I've had since using DFX 4.0 with Road Runner as well as with the latest Ride Runner. If I'm browsing music, when I'm in a folder containing mp3s as well as subfolders, it only shows me the subfolders. But if I'm in a folder containing only mp3s, it will show the mp3s. The music files really are there - if I tell DFX to play a folder containing mp3s as well as subfolders, all music in that folder and subfolders show up in the playlist. In fact, this is the only way I can play those mp3s if I can't see them in the browser. THe only other option is to use the Search feature to see them.
    Also, its only DFX that does it, other skins I've tried don't have this issue.
  9. #3989
    Jun 2009
    music
    I am trying to set up music on ride runner with the dfx 4 skin and for some odd reason rr can not find any music. I have tried a couple different programs but no luck. Do any one know a program that I might be able to use to help me out.
  10. #3990
    Jul 2006
    What type of files, .mp3, etc? Did you set up the audiofiles= entry in RR.ini?
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
