Thread: DigitalFX 4.0
  1. #4051
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    From a PM I got a couple days ago, he has completely revamped the command structure. "Select" and "Load" are out. So no more "Load Journey", it will be "Play Artist Journey" ect.
    I have my car set up for Remote Desktop so I can configure everything from right here
    My Fiero Build Thread
  2. #4052
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    you'll have to shout from the living room to the car for it to pick your voice up lol...
    next thing i will hear is John can remote start his car from the house soon.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  3. #4053
    Sep 2009
    I tried to add TV button to my menu using BlueZX3's editor.
    I added RR Command:
    LOAD;AVerTV.SKIN;AVerTV;C:\WINDOWS\system32\AVerTV.exe;!AVerTV_Control
    But no button appears in menu.
    I also noticed that I lost my volume icons and also volume doesnt work !
    what am I doing wrong?
    I tried to fix this adding BlueZX3's DFX 4.0 Fixed scrns files which I downloaded and replaced in suggested folder
    I also tried to use suggested Solution: You need to install the DigitalFX custom font, "DigitalFX Font.ttf" in the difitalfx/helperfiles/fonts folder.
    But I have no fonts folder in helperfiles , I do have it elswhere, but there is no DigitalFX Font.ttf file in it !
    All I want is to setup a Tv button and embbed avertv sw to it
    And if I succeed , then to try to add phone button and any mobile sw to use my mobile phone through bluetooth.
    Please help
    edit:
    sorry guys I just found how to make other menu buttons appear by pressing and holding down any menu button !! so I guess no need to answer on that, sorry again
    Do only 2pages of menu buttons appear ?
    Anyway my questions about volume icons dissapearing still need an answer
    One more thing, How can I make avermediatv work each time I hit tv button? I read the embed programs post, but I am doing something wrong
  4. #4054
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by JohnWPB View Post
    Yikes E! Sprained or broken ankle?? I have broken both ankles at different times, and it is NO fun at all.....
    Swollen, it's what happens when someone stands on the ankle and it turns over.
    It's not too much of a biggie, I have twisted, turned over, sprained both ankles a number of times to varying degrees of severity but luckily never broken. First day and a half are the worst.
  5. #4055
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by carputer1 View Post
    Ummm how do you think I turn the CarPC on from here to access it by remote desktop I just remote start the car from here at the desk, wait a couple minutes, log in, do my changes, and then turn the car back off.
    Quote Originally Posted by Demik View Post
    Yes, in the last release there are 2 menu screens. In the next release there are now 3 menu screens.
    I am not sure what the problem is with embedding the application, as I do not have it here to test, maybe someone else can assist.
    As for the volume icons, they are actually a font. If the other icons on the bottom row are showing up, I am at a complete loss as to what it could be.
  6. #4056
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Ya know I was doing that fore a while but guess it escaped my mind last night..
  7. #4057
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    A Button in the skin can be used, but thats not really a good option. You would need to touch the screen to fire the command, and if you are doing so, could have just pressed the button you wanted for the most part.
    Secondly, logistic wise, there is no just easy way in the skin to put a button on every single skin, to make it start listening. As every person will probably not use the plugin, putting a button on all skins would be a waste of screen real estate.
    I understand what you are saying, but in normal use there are 4 or 5 skins I use a lot, and the rest rarely. From your perspective as a skin creator, everybody's 4 or 5 or more will be different so you would have to put the button on almost every skin.
    But for me, once I have your finished product then I can and will tweak it to my own taste, so adding such a button wouldn't be that hard since I've done it before. And, I think it would be easier than trying to use that unused switch location on the steering wheel. Although that would be more sexy...
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  8. #4058
    Nov 2007
    PA
    On another note...
    What if we could make the pre commands "Kit", and instead of the beep confirming, a recording says "Yes, Michael"
  9. #4059
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    I mentioned this awhile ago and forgot about it till I reinstalled pc in car..but my weather sattilite isnt correct the date is 8-25-09 for the sattalite.gif from wsi.com, the 5 day and the radar are up to date..even after the I uninstalled Dfx and RR and reinstalled. still does this! I deleted sattilite.gif and then load maps again but still seems to download the 8-25-09 image.. any idea's?
    ** UPDATE
    INSIDE THE WEATHER.INI
    http://images.intellicast.com/WeatherImg/SatelliteLoop/hiusa_None_anim.gif"
    I triied it inside address bar without RR running and sure enough its the Aug 25th image.. they must have changed there address since then.. guess I'll go get the new one. I'll post the link incase someone else asks the same question.
    Here is the new link: works like a charm now
    http://images.intellicast.com/WxImag..._None_anim.gif
    Did it.. Done it... now I got to keep the neighbors kids away!!
  10. #4060
    Dec 2008
    Being I have an automatic transmission, I am seriously thinking on putting a durable momentary switch on the drivers side left foot rest for the toggle. Much like the OLD cars had for turning on/off the high-beams. This way I do not even have to move my hands from the wheel to initiate it. (I do not have steering wheel controls).
    My foot is resting there 90% of the time anyways while driving.
    hmm.... you know, that is brilliant. i was pondering where to put a switch too, and this sounds like the perfect place. people wouldnt even realize youre hitting a button to activate the voice control. i could freak them out by telling them its mind-activated... this would be ideal i think... its nice that it raises up a bit so your foot can feel the housing before it pushes down.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
