John you are a genus!!! :cheer2: that mixing the tags worked!
now what about the cd loader scrolling or changing font size?
how do i load an icon to the gps button??? I have done it befor but now I
can't remember what I did...
Printable View
Depending on what program you are using it should be automatic, if not you drop a PNG of choice in the folder, and use blue's button config. If you are just using iGuidance or something you push and hold the button, make sure you use the "Iguidance" button in the button selector and it should be there.
Thanks dougw133, but no I am not using a standard gps, I am embeding Roadnav, I could not get i t to change with the button editor...I finally got it to change by changing the skin.txt - png
You can open the RM_DiskChanger.skin in notepad and find This line: (Copy the skin to the desktop or something as a backup in case something gets screwed up)
L,15,127,171,31,#DFX1R#,#DFX1G#,#DFX1B#,18,#DFXFon t#,"RM_DISK1NAME","CENTER"
Change the "Center" on the end of all of the disk name label to "SCROLL-CENTER.
Like this:
L,15,127,171,31,#DFX1R#,#DFX1G#,#DFX1B#,18,#DFXFon t#,"RM_DISK1NAME","SCROLL-CENTER"
You will need to do this for all 10 of the lines that have the RM_DISK # NAME in them.
I have went ahead and edited the skin here for the next release to include this change.
Thanks so much john, I will give it a try!!
and let yo know if I screw anything up :washing:
Got it!!:clap2:
New problem, how to increase the size between the title and the number of songs, the top 1/4 of the letters are cut off... I tried to change the font size but it only made it smaller and still cut off, exactly the same but smaller.
If it is too hard, then I could take out the number of songs, If you could tell me how....
I also stopped the scrolling of the main title that was scrolling along with the disk names.
It seemed like too much. Kinda made me dizzy....all the movement (hope you understand what I am talking about?)
anyways, thanks for the help!
Never mind I found skin editor!!!
I would like to know why if I use winamp and want to choose the album with cover and click play album I can't play because there isn't nothing in playlist but if I use WMA it work fine. Where is the problem?
