Like Tree1Likes
Thread: DigitalFX 4.0
  1. #4111
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by jessekilner View Post
    damn good question.. I surely would like to know the phone list supported too I gave up as it was split into so many threads that I got lost!
    Well it depends..RR Per say doesn't handle the phone, as the plugins do the work. The most current RRMobile plugin uses a program called bluesoleil. You need to have this program for the plugin to work. You can check there website for the list of Phones Supported. Here is the link . They require a login now to use it but it is free to register, here is the current LG Support list, but don't get your hopes up. I have an LG Voyager and it has never worked with any BT Apps. Unfortunately the LG's are a little different.
    ID Manufacturer Model Contact Message
    232 LG Joy Y Y
    233 LG KE970 N N
    234 LG KG338 N N
    235 LG KG90 N Y
    236 LG KG99 Y Y
    237 LG KG800 Y Y
  2. #4112
    Nov 2007
    PA
    Quote Originally Posted by drewbp View Post
    Just thought I would share: My main car G35 has my primary car computer with a touch screen and all the works. My 10 year old Sentra needed something but I cant afford a touch screen for it right now. I have a 10 year old Dell laptop that I have put to use. I spend most of my time in this car, I have a 112 mile round trip to work and this car gets excellent gas mileage, so I have been playing with a vnc from my pocket pc to the computer. I have created a skin from DFX 4 to fit the vnc'd screen size of my IPAQ.
    That is pretty freakin cool there drew!
  3. #4113
    Jul 2006
    Quote Originally Posted by dawnn View Post
    Thanks for the help John, yes I believe those are the codec's I have.
    I still have problems for some reason, RR hangs some times, I have to close it
    with the task manger and it leaves the codex running at the bottom of the task bar.
    I have:
    K lite codex pack 5.1.0, I also have divx codex, ac3 filter.
    There are three codex/filters/scripts? running while playing a video. Is this normal?
    FF video decoder and FF audio, and Haali media splitter these three continue to run after
    a forceful RR shutdown, Only way to get rid is to restart. (that I know of??)
    Look in your rr.ini and see what value localdatacaptureinterval is. If it's anything other than 0, set to zero to see if it fixes the hanging issue.
  4. #4114
    May 2008
    Bend, OR
    Quote Originally Posted by Dougw133 View Post
    232 LG Joy Y Y
    233 LG KE970 N N
    234 LG KG338 N N
    235 LG KG90 N Y
    236 LG KG99 Y Y
    237 LG KG800 Y Y
    Thanks. Though sadly: "Note: CDMA cellphones are not supported by this tool currently." So that means anyone with verizon is S.O.L which includes me.
  5. #4115
    Sep 2009
    Quote Originally Posted by barnyard View Post
    barnyard is that setting under weather??
    [Weather]
    cityweather=New York,NY
    weatherunits=USA
    weatherdegress=º
    localdatacaptureinterval=1
    WeatherUpdateInterval=0
    weatherpreset01=
    weatherpresetID01=
    weatherpreset02=
    weatherpresetID02=
    weatherpreset03=
    weatherpresetID03=
    weatherpreset04=
    weatherpresetID04=
    weatherpreset05=
    weatherpresetID05=
    weatherpreset06=
    weatherpresetID06=
    weatherpreset07=
    weatherpresetID07=
    weatherpreset08=
    weatherpresetID08=
    weatherpreset09=
    weatherpresetID09=
    weatherpreset10=
    weatherpresetID10=
  6. #4116
    Sep 2009
    ME TOO!!!
    I was able to get my phone razr 3vi to work with bluesoil, but I could not get the skin to load
    whenever I went to the phone button it said "could not load skin cause a jpeg was not found"
    (something similar to that, its been a few days ago) so I couldn't get it to load so I deleted everything to do with the phone....
  7. #4117
    Nov 2007
    PA
    Quote Originally Posted by steven765 View Post
    Not quite...Not all verizon phones are CDMA. Most of their smartphones have been but just this fall quite a few Quad Band GSM Phones have and are coming out. HTC and Samsung. Samsung seems to be well supported by the Bluesoleil. Samsung's new Omnia II looks amazing, check it out!
  8. #4118
    Nov 2007
    PA
    ME TOO!!!
    Do you have skin files for the plugin?> Currently there are none for DFX 4 but will be for DFX 5 as John showed us. You could download the sample skins and drop them into your DFX 4 folder.
  9. #4119
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    man thats sux.. i got a EnVyII thats CDMA
    Did it.. Done it... now I got to keep the neighbors kids away!!
  10. #4120
    Oct 2009
    thanks jesse for the info. I had to go into safemode to get that resolved but were good now.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
