Like Tree1Likes
Thread: DigitalFX 4.0
  1. #4131
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by Enforcer View Post
    RRcan? Is that a toilet plugin?
    What software you use today for this function Enforcer??
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  2. #4132
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    MP3Can, for all of your CanPC needs
  3. #4133
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    ok ok, funny boys... RRCAM.... "M"...
    is there any better software for replace it? I just find the "capture!", could you tell me what are you using nowadays?
  4. #4134
    Mar 2009
    men 2
    Why is this happening
  5. #4135
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by achillealb View Post
    First of all make sure you have your adobe flash updated...
    then use the skin editor and remove the 2 boxes (buttons if I remember) above and beyond the clock... (in both menu and menu2)
    I remember that something like that happen to me when I update the RideRunner...
    this procedure should solve it...
  6. #4136
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, those "button" area's are to change the visu prev/next and where only ok if you where using the stationary logo/pic menu styles. This has been address and already fixed in the next one....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #4137
    Jul 2006
    Quote Originally Posted by JohnWPB View Post
    You will need a button to press to let the system know you are about to speak. This does a couple of things, it mute's the audio so if you are jamming out, press the button, audio is muted, so you the system can clearly hear what you are saying. When the command is recognized, the audio will resume.
    Hooking up a button can be done in many different ways.
    - Jebus designed a Serial Port Plugin so you can hook a button to 2 wires on the serial port.
    - Use an available input on the Fusion Brain.
    - Use CDRSkull's JoyPad plugin to take any old USB game pad to add a button
    - Using RR's keytbl.ini, you can set a key on a keyboard, that when pushed will trigger it to listen.
    - Use a mouse/trackball and assign a button.
    - iBus
    - Girder
    John...
    How difficult would it be to have it completely voice activated?
    You could have the system always waiting for a specific command to activate.
    "Computer, arche!"
    Maybe someone can compile a module to emulate the seral port commnd when the voice phrase is heard.
  8. #4138
    Jul 2006
    Quote Originally Posted by Dougw133 View Post
    On another note...
    What if we could make the pre commands "Kit", and instead of the beep confirming, a recording says "Yes, Michael"
    Better yet. how about custom reponses using text-to-speach.
  9. #4139
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by CannonBaller View Post
    Well, it's really not a DFX 4/5 process. This is possible through the plugin made by Jebus, John is just customizing aspects of that plugin for DFX 5 countability etc.. Follow the thread Jebus has up as it is ever developing each day.
  10. #4140
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Actually the audio volume is lowered to zero, and set back to previous level, not muted...
    "Computer, arche!"
    The precommand was removed due to false recognitions in the vehicle environment....
    The manual VR attention trigger is the best overall way to achieve optimum results.
    The vehicle manufacturers use this technique, and they spend millions on R & D...
    ...JJG
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
