Like Tree1Likes
Thread: DigitalFX 4.0
  1. #4171
    Dec 2008
    Quote Originally Posted by treetop777 View Post
    Thanks. Got it. (on sale!)
    yeah the sale price is pretty close to what you can find them for other places.... i got mine for $34 shipped, but the retailer was questionable. i did get it though, and john's example there is in line with my results. super clear, already does a good bit of noise cancelling itself (without software) and absolutely obliterates the built-in mic on my 6month old HP laptop.
  2. #4172
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    (RR 11-05 fesh DFX install DFX also) skin's audio browser no longer has one touch play in standard mode, database mode works but I prefer standard. This seems to work on other 3 skins only DFX seems effected. Any suggestions.. the problem seems as if DFX isnt sending the command to winamp in audio broswer skin.
    Did it.. Done it... now I got to keep the neighbors kids away!!
  3. #4173
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    "one touch play" ?????? I'm not sure exactly what you mean.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #4174
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Open RRConfig, go to the Music section, Page 1.
    In the middle section, on the right, put a check mark in "Play on list click".
    That should take care of it.
    My Fiero Build Thread
  5. #4175
    Aug 2008
    oh I always have that checked..never leave home without it..lol, I thought that was the issue also last night. I went into rr.ini to verify it was saving..it was, what I did notice was my lastbrowse path had a number at the end .. E:\music\Hinder\Lips of an Angel ;7I dont recall seeing that before but Im assuming thats because I didnt use resume music settings prior. ;7 must be the playlist number???
    update*
    What did it though was updating the RRmedia to 1.2.
    weird though none of the other RR versions required that. What I mean by one touch is after selcting standard mode then you can select artist and it will load album instantly then just touch once and it wiill start playing that album..without adding or removing songs from a playlist... I guess I find it more convient. Here was the strange part though after a fresh install of Carwings that would work normal but when I loaded DFX the music browser would show everything but it acted as if it wasnt sending the command to winamp to start playing! After DFX would failed to work with the media then none of the other skins installed would work in audio anymore after. They would before DFX triied though. I had to reininstall RR to get other skins to work again. So I finally 1st time ever in 2 years updated the RRmedia After the 1.2 update of RRmedia it's working normal.
    Im gonna head over to that thread see what changed for this/last month version. See if I can pinpoint that, as now I'm pretty sure DFX default intall wont work with the newer RR unless you get plugin updated. Can someone verify this? If the updates are in the RR directory it will work! Try this with 100% clean RR 11-05 and fresh DFX install, you should have same behaviour I seen. I have installed DFX many, many times prior and never had that issue before. Same PC, same windows only thing diff is the RR version..lol
  6. #4176
    Aug 2008
    I searched keyword and nothing seems to popup what im looking for maybe someone can redirect me.
    Im anticipating creating a skin within DFX that will control the entertainment consol program from Soundblaster's "entertainment consol".. as it has Sub/surround settings/fade. I have winspector and embedded app (who knew the window name would be !32770)...grrr
    I dont like the feel, so I want to create some of my own buttons that communicate with it just like RR does with winamp... "entertainment consol" don't have keyboard shortcuts and I already modded the .bmp's in the program but it's just a pathetic layout the buttons are too small.. and the consol only has one size think Igo without IGOmySize....any suggestions on how I find the commands or where I should be looking?
  7. #4177
    Oct 2007
    can anyone provide a digitalfx screen for mobilephone.net ?
    there are references in this thread to some screens being available but couldn't find any while searching
  8. #4178
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Here is another sneak preview of the New Main button app chooser.
    Also, it no longer requires a skin reload. Buttons can be used directly after setting them.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #4179
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Thumbs up
    MANY thanks to BlueZx3 for adding in the new menu button chooser in the above post! It is much faster, you stay on the same screen, and no longer have to dig through 3 screens to try to find something. Now you just have a nice alphabetical list to browse from.
    I then added in a nice description of each item, when you select it in the list, to show at the top of the pop-up screen.
  10. #4180
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Oh, BTW, you can ignore this post if you want, as it is not technically "CarPC" related, but it is related to a car build at least
    I mentioned I am headed to MN the day after tomorrow, and will be helping on the build. If you don't mind, click the below link to go to the site, and then you can close it if you want. I am just trying to get the Google map hit counter to show a lot of activity for Tyler and his family to see from where in the world people are visiting the page from. Thanks!
    http://www.tylerstoy.com
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
