Page 43 of 557 FirstFirst ... 33343536373839404142434445464748495051525393143543 ... LastLast
Results 421 to 430 of 5570
Thread: DigitalFX 4.0
  1. #421
    Newbie thebulletdodger's Avatar
    Mar 2008
    Quote Originally Posted by thebulletdodger View Post
    greatskin John,
    I ran into a few issues, but most have already been posted here. One issue I didn't see or maybe overlooked was with IG and the fast food shortcut. It will go to the POI menu instead of the restaurant list, all the other's work fine.
    I just updated to IG4, the shortcut works now.
  2. #422
    Jan 2008
    Santa Clara, CA
    Is it possible to have both DXFX2.5 and 3.0 installed on the same computer and select which one to use from RRConfig?
  3. #423
    Oct 2007
    Quote Originally Posted by Darkman613 View Post
    Yes it installs in a seperate directory structure
  4. #424
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    With a few small changes, MediaLaunch works. Of course this skin is great as-is!!! The new button switching is very nice....my hack on the skin doesn't touch the .skin files. It just adds the ability to select a MediaLaunch button...which points at the .skin files included in the zip.
    Media Launch for DigitalFX 3.0
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  5. #425
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by Morpheus2010 View Post
    When i click next or previous on dfx3.0 or 2.5 it only rewinds or forwards the video or movie. How do i get preview and next to work? please help. just pm me and thanks in advance
    This has been fixed for the next release. I re-did that skin, and removed the FF and RW buttons, as there is a slider bar to tap anywhere you want to jump in the video.
    Keep in mind the NextTrack and PrevTrack buttons will only work if you have multiple videos in the SAME folder. This is not a skin thing, but a limitation on how RR handles the videos.
    My Fiero Build Thread
  6. #426
    Jan 2008
    Santa Clara, CA
    Quote Originally Posted by morris_the_cat View Post
    John, I noticed a few things:
    2. I am glad u made a skin for RREarth. Something isn't right in it though. I got it running fine under DXF2, but in DXF3 it doesn't properly embed the window & turn on GPS. Not sure if I should be posting this item here or in the rrearth folder, but since I have issues with it running in this skin only, then I thought here...
    Same here... any idea?
  7. #427
    Oct 2007
    Is anyone else still having problems with Sirius/Music/Radio not muting when iGuidance is speaking directions? I have set the volume on the GPS to 100% and the volume on the system to 70% I have enabled iG Native checked of all the options in the RRconfig under ig Native, i did search through many threads and that seemed to be the fix. There was also a mention of something to do with John's ExecTbl.ini vs. the RoadRunner one but I did not understand that any help.
  8. #428
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    Quote Originally Posted by dmistry View Post
    This is always a hit or miss on my system. Sometimes it does, sometimes it doesn't. But i have mine to lower the volume on directions and not mute. I've gotten to the point of just 'living with it' because it's not a huge concern for me
    I also have a request for perhaps a tiny addition.
    Is it possible to put iLists in the 'Lyrics' tab?
    it seems like it would be easier than having to hit the down button. If that's to much trouble then no worries, i can live with what's there.
    Also i posted before how the menu item for the lyrics tab says 'Lyrics', unlike the universal all caps such as 'LYRICS'
  9. #429
    Oct 2007
    Another question the top left of the menu and menu2 skins if you click there are 2 different icons that appear what are they? Something to do with looping the music or something.. this may be a silly question
  10. #430
    Jun 2002
    Virginia
    If I understand the icons you're referring to, the one with the squiggly lines means that the songs are playing in random mode and the oval one means that the playlist is in repeat mode.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
