Thread: DigitalFX 4.0
  1. #4351
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by maceo4 View Post
    I was wondering if anybody could point me to any threads regarding setting up Traffic Cams in DFX 4.0, I was able to download the plugin, and register the dll, I added x, RRTrafficCams into my menu.skin. However it didn't load...I looked in the Exectbl file and saw it was looking for some .exe which I don't think comes with the plugin, so I changed that line to 'load;RRTraffficCams', but when I run DFX 4.0 it tells me that I haven't installed the plugin, not sure how to proceed from here though, any help would be appreciated.
    I'll have to check later today but I am not sure if it's "load;RRTrafficCams"
    It might just be LOAD;Traffic, or LOAD;TrafficCams
  2. #4352
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    DFX 4.0 was originally done with the standalone exe in mind, not the RRPlugin.
    I know John did some screens for the RRPlugin, but not sure if he ever released them.
  3. #4353
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    John, I know that is a little bit late, but can you add a button to add the current played song to one of the virtual disks?
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  4. #4354
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    There is one currently. It's in the audio player scrn "Song To Disk" button.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #4355
    Sep 2009
    Reading, PA
    Update...
    Quote Originally Posted by TFCommanderBob View Post
    RR December 09
    DFX4.0
    XP SP3
    Winamp 5.13
    I've managed to rip a cd onto the hard drive, and get it to show the album art, and hide winamp on load.
    Some Retail CD's have something else on them, like a macromedia file or something. For instance (sorry for the random music selection, I don't even really use CD's anymore!) 2 Reliant K cd's and a Linkin' park cd load a little flash file outside rr that wants you to go to their website, nothing else. Nothing auto loads in RR and I can't find a button or something to get it to search D:\ for a disk, though the computer recognizes a disk was inserted. If I put in my System of a Down CD it autoloads just fine in rr (no flash program). How can I fix it so that any CD will autoload correctly? I DID change the autolaunch.ini from E:\ to D:\, and this is what it says at the end of the autolaunch.ini code
    Code:
    CDCOMMAND=Load;Audio_Playlist.skin
    Currently the autoplay function of XP is set to Take No Action, if that makes a difference.
    I still haven't been able to figure this one out. If I try to explore the bad CDs in XP, I can only see the autorun file, movie file, flash file. None of the mp3 or wav or whatever they are. When I insert the CD, winamp outside of RR can see the songs on it and play them- but the winamp in RR can't/displays "1."/ plays the first song in my browser. The CD does say loaded in the changer. Hitting Play CD doesn't work, though hitting Eject does. What am I missing?
    I've tried to provide every detail possible so that someone can help me fix this in one clean shot
    The other part: I insert the SoaD CD and it auto loads just fine and plays. If I clear the playlist, I can't seem to get back to the loaded disk? It might even be a button that I don't know to click on, but I can't get back to it unless i eject it, which seems a bit ridiculous.
    Indeed, it wasn't intuitive to me to click on the CD symbol. I was looking for a load cd button or something. Found that nugget in a post using 'play cd' as keyword.
  6. #4356
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Do you have windows set to show All files. I cant remember if windows hides the *.cda files that are on a Normal Retail CD. This might be the case and RR Doesn't understand .cda files but WA does.
    If your talking about the Disk Changer, that has nothing to do with the physical CD in the drive. Those are virtual Disks.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #4357
    Jan 2007
    I am having an issue trying to change the logo under dfx4 using ride runner. When I change the logo the skin either freezes without changing it or says changing, however I still have the big white clock there. Is there something im doing wrong...or a way to manually change it??
  8. #4358
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    To all I am a user of Road Runner and DigitalFx, it is all so cool.
    I currently use vlc to stream live video from rear facing cameras using the following commandline:
    "C:\Program Files\VideoLAN\VLC\vlc.exe" dshow:// :dshow-vdev="AVerMedia C038 USB Capture Card" :dshow-adev="none" :dshow-size=""
    My question is how would I incorporate this into a Road Runner/DigitalFX button?
  9. #4359
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    thks Blue, my mistake!
  10. #4360
    Sep 2009
    Reading, PA
    Thanks! I did have windows set to show all, but for whatever reason it doesn't show the music files. At least I won't be trying to make it work when it wont!
    So if a friend gets in with a new cd, it has to be opened outside of RR and ripped to the hard drive to play it? Kind-of sucks but still workable.
    Thanks again for the info...
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
