What happens when a particularly good foot tapping song is playing and you do?
Printable View
what will cause the gps gauges to not display the number of satellites or the speed? I am getting a gps lock and the lan and lon are showing at the top
Thanks,
yonu
Ok, I've found the problem putting this 2 lines in the video player skin
C,0,230,800,400
A,0,0,800,400,
Now it's all ok...thank-you
I'm not clear why updating to the latest RR has broken the DFX4 skin, but when you try to search (in music), it throws an error on RM_Search.skin about RM_Menu_DN.png being missing. I removed the reference from the skin file and it seems to work fine now but without knowing what the file was its hard to say what's missing.
I've had a lot of issues with RR latest update. Vide screen I can't leave, HD radio freezes although dare i ask questions about it, it's always DFX's fault. I love RR but I don't understand why it's seemingly only "ONE" skin friendly these days. I understand things will happen and skinners will have to adapt, but every answer i get is just "Use carwings"
Maybe the skin parsing in the latest RR is more strict and the file has been missing all along and its just now throwing an error. I can't imagine updating RR would delete a file from a skin folder. At least its an easy fix for this particular instance.
I just did a fresh install of Win7 (from XP using DFX 4) and I'm just using the default Carwings til the next DFX version comes out only because of the issues I've been reading about. I know some are fixable (like the video one), but I'm just gonna hold out for the updated skin since I'm sure it will be fully compatible/working with the latest RR.
Now we just need the new skin to come soon. :)
Im doing the same, just waiting. We seem to be loosing backwards compatibility.
I hope that DFX5 has more ilists. I love the skin but for instance when searching for music, the search results (at least on mine) aren't an ilist and that makes it difficult to browse through the results if its more than one page. If i knew more about skinning I guess i could convert some of them myself.
