Like Tree1Likes
Thread: DigitalFX 4.0
  1. #4411
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Dougw133 View Post
    I've had a lot of issues with RR latest update. Vide screen I can't leave, HD radio freezes although dare i ask questions about it, it's always DFX's fault. I love RR but I don't understand why it's seemingly only "ONE" skin friendly these days. I understand things will happen and skinners will have to adapt, but every answer i get is just "Use carwings"
    The simple reason that the carwings skin is mentioned when u ask about a problem is that it's a bit more simpler than dfx and if we devs can reproduce the same issue on our ends then it is more likely to be an actual rr code problem then just a skin related isssue.
    Quote Originally Posted by TheDoctor1971 View Post
    Maybe the skin parsing in the latest RR is more strict and the file has been missing all along and its just now throwing an error. I can't imagine updating RR would delete a file from a skin folder. At least its an easy fix for this particular instance.
    This would be correct if one was updating from a much older riderunner, before the extra checks were put in be me, as the prior code just ignored the errors and continued to chug along. Or, that file somehow got deleted...
    Correct, just updating rr will only update rr's files, does nothing to the skins folder execpt to update the default skin if you specified to install it the first time around.
    I hope that DFX5 has more ilists. I love the skin but for instance when searching for music, the search results (at least on mine) aren't an ilist and that makes it difficult to browse through the results if its more than one page. If i knew more about skinning I guess i could convert some of them myself.
    searching for music via rr or rrmedia? I can help u (post needed lines and where they go) if you give a little more detail.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #4412
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    This would be correct if one was updating from a much older riderunner, before the extra checks were put in be me, as the prior code just ignored the errors and continued to chug along. Or, that file somehow got deleted... .
    Maybe an option should be added to be able to ignore the errors and allow RR to chug along so it will work with older skins which may have 'errors' in them.
    Otherwse we are losing tha backward compatibility, which G harps on about.
  3. #4413
    Newbie TheDoctor1971's Avatar
    Dec 2009
    Thanks Blue ZX3, its possible I was using an older version (I'd swear I was using the december one but maybe not) as I just got around to building an enclosure etc. for my truck pc. I've been planning it for at least 10 years but until this past month its never really come together. I gotta say, i'm lovin' it.
    The screen I'm referring to is the search results in DFX4 when searching for MP3 files. Its kind of a circuitous route but I hit Music/Browse/Search and choose a method.. e.g. Title and the results that come up aren't an IList (for me). It could be the normal playlist screen for all I know. I looked around the skin but I just haven't had time to really dig into learning how they work yet. I really dig the IList as it works just like my windows mobile phone and is quite intuitive.
  4. #4414
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Enforcer View Post
    Well this particular type of error is usually easly fixed. E.g. You can't load a screen for which has no skin file or if it's a graphic issue(missing) then one just needs to point it to the correct graphic.
    How about if your car had an option to disable the engine/oil dash light for those ppl that figure that, yeah I don't need that light(s), car is running just fine whether it's just about to run out of oil or not...
    Just seems kinda silly to have such an opt out option, to me.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #4415
    Jan 2005
    ant idea how to get the gauges working again I am not sure why but they have stopped working the other gps data on the screen still work though I also get no response fromt eh cpu gauge
    thanks,
    yonu
  6. #4416
    Dec 2008
    i recently lost my gps volume control. nothing was changed, and everything is set correctly... even the gps speed guages work, but the volume doesnt change with speed. ive pretty much given up on fixing problems for now though, dx5 will be out soon enough
  7. #4417
    Jan 2005
    i know 5 is coming but i plan to stay with 4 as i have made several changes to some of the screens to make them more friendly for my setup and don't want to have to do it again
  8. #4418
    Jan 2005
    well i got the issue i was having fixed was the flash player reinstalled it and they are working again
  9. #4419
    Dec 2009
    After some puttering around, I find that my issue with the ilists and music is limited to directory mode lists. If its showing folders the ilist doesn't work. A playlist with songs (not folders) seems to work just fine, I can drag the list up and down to my hearts content.. At this point I don't know if its a RR issue or a skin issue. I still don't know quite enough yet but I'm working on it.
    The directory ilists in the carwings skin work ok for me it seems, so its not directory ilists that's the issue.
    Ok.. last edit. It seems the fix for this is in post #3700 of this thread. Just took me a bit to find it. http://www.mp3car.com/vbulletin/rr-r...in#post1323317
  10. #4420
    Jan 2009
    Quote Originally Posted by kapone View Post
    I must be doing something stupid, or there's something seriously wrong here...
    I installed the 2010 release of RR (installed just fine), tried to install DFX4, which crashed at "FixFlash", 22%. Had to manually kill the process. Tried a couple of times after that with various combinations of reinstallations, including turning off AV, firewall etc, to no avail.
    BUT, now my default font in IE has turned italic??? What's with that? And I can't seem to find what caused it, or what to turn off, to restore it back. Is this an RR issue or DFX4 issue??
    This was actually Windows 7, but yes, already did Windows restore, and life is back to normal.
    But my concern is that these pieces of software are going to be running in a moving CAR. If they are not stable even during installation, should I expect lot of glitches during operation? Not to put down RR or DFX, I think both are amazing, but I'm just a lil concerned about stability.
    STILL crashes at 22% (FixFlash.exe), and this is a brand new installation of Windows 7 32 bit, with nothing but the base install and RR on it. Any ideas?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
