Thread: DigitalFX 4.0
  1. #4441
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Microsoft Windows XP [Version 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\Marteline>ping JOHNWPB
    Ping request could not find JOHNWPB. Please check the name and try again.
    scooby dub John, where are you? hehehe
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  2. #4442
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Quote Originally Posted by Deadmaninc View Post
    Adding a 3rd page of menu buttons
    This requires a lot of editing in the Exectbl.ini and the skin.ini to create the button assignments. You also need menu3 skin files, both the .png (which can just be the same as menu and menu2) and the .skin file, and you need to edit menu2 so that when you hit menu it goes to your menu3 page instead of back to the main menu page.
    This is a lot of work over several files. Start looking at the files in the skin folder, and it will become clear what to do.
    When you have researched these files and start working, I can help further with specific questions.
    I believe that when DFX 5 comes out it will have 3 menu pages, so you might want to wait.
    I created a 3rd menu page, and find that I rarely go there, as the 16 items on the 2 pages is really enough.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  3. #4443
    Nov 2008
    4.how do i add picture folder to the picture button. i used rrconfig and added the folder via the picture viewer path then when iu click the button it shows a black screen click browes and it shows 0x at the top and black screen.
    This is a simple fix. You need to change the path in the ImageViewer Config file to point to the folder where you have your pictures. The Config file is found in "RoadRunner\ImageViewer". Change the line "Init_Path = G:\Pictures\" to wherever your picture folder is. For instance: "Init_Path = C:\Documents and Settings\My Documents\My Pictures"
    Hope that helps
  4. #4444
    Feb 2007
    Limassol, Cyprus, Europe
    Foobar Problem
    I wasn't sure where to post, since my problem affects foobar, digitalfx and the rrmedia plugin.
    It seems like the RM_ADD1 command doesn not work when using foobar as the player. On winamp it works perfectly. Specifically on the RM_Media.skin screen (the one you browse to by clicking on the "Browser" button on either the playlist or the player screens), the button labeled as "Add Sel", seems to have no effect when foobar is setup as the music player for Riderunner. Using winamp, it works prefectly fine.
    Does anyone have any clue? Is it a known bug? I've searched around and I got no clear answer. It looks like a fix was announced before some moths but I'm not very sure.
    I'm using the latest version of anything mentioned, except from foobar, which was tested using versions 0.9.6.6 and 0.9.6.9 on two machines under windows XP SP2
  5. #4445
  6. #4446
    Feb 2007
    Quote Originally Posted by Enforcer View Post
    Sounds more like an RRMedia question to me. (Is RRMedia compatible with other Audio players)
    Propably you're right. But then again DigitalFX and RRMedia and so heavily bound together!
    If an Admin believes it's a mistake, my apologies and please move it!
  7. #4447
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by qpwoeiruty999 View Post
    DFX & RRMedia are not bounded together code wise by any means. Its just the fact the John heavily helped to do a ton of testing as well as integrate into the dfx skin.
    That's in a nut shell is correct. At RRMedia's release time, WA was the only available media player. I have already fixed this in the 1.3 version.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  8. #4448
    Feb 2007
    Sorry, English is not my native language and in fact, though i can express some thoughts in English, I don't know if I'll ever be able to "think" in English. Anyway, i didn't mean that they're bound together programmatically at least but DigitalFX is maybe the major "consumer" skin of your plugin (or is that major skin period?!)
    So, is the 1.3 version released somewhere we can get it? Winamp is a no-go for me, since I'm facing impossible-to-overcome problems with its ASIO support. Foobar is excellent in this aspect!
    Thanks a lot for your reply!
  9. #4449
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by marteline View Post
    Reply from JohnWPB: bytes=32 time=27 Hours 4 Minutes
    Ping statistics for JohnWPB:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times 32 time=27 Hours 4 Minutes
    ZOIKS! I have been busy working on another project, the Car...
    I have been working on the skin a little bit here and there, just no like I was there for a while almost every waking moment that I was not at work or sleeping.
    Also, Mitch has offered to create the installer for the release, so that is one thing off of my plate. But, More so, it will ensure that things are all correct to work well with the latest RR release. Thanks Mitch! I will be contacting you when it is ready
    My Fiero Build Thread
  10. #4450
    Apr 2009
    harrisburg pa
    Quote Originally Posted by drewbp View Post
    Ok all that translates to .... i don't need a third page. i thought it might be something semi simple... at this point i dont need a 3rd page lol. Thank you very much for the time and help tho.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
