Like Tree1Likes
Thread: DigitalFX 4.0
  1. #4471
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    depends on how your useing it, and for what ,
    pm me your idea and i will help i don't want to fill johns thread with really non related to his skin .
  2. #4472
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by carputer1 View Post
    Done!
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  3. #4473
    Raw Wave
    Jun 2002
    Virginia
    02/01/10 Version of RR Broke Video?
    Is anybody having trouble with video while using the 02/01/10 version of RR with DFX?
    When I launch a video the video buttons appear at the bottom per usual, but once the video goes to full screen after a couple of seconds I can't get it back out of full screen. It used to be that I could tap the screen and the buttons would pop up again and I could easily browse for a different video, go back to the DFX menu screen, etc. If I have a keyboard I can hit the escape key and it will take me back to the DFX menu screen. In the car, however, I have to reboot in order to get going again.
    This problem started immediately after I upgraded from RR 05/09 to RR 02/10. In trouble shooting I made sure I made no changes other than the upgrade before testing. All works fine if I switch to the Carwings skin so it must have something to do with DFX and the new version of RR.
    I'm using Media Player Classic.
    EDIT: The solution is found in post 4426. For anyone else having the problem add the following lines to video_player.skin:
    A,0,0,800,600
    C,0,250,800,250
  4. #4474
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by kbreeden View Post
    A,0,0,800,600
    C,0,250,800,250
    Yes... I face that problem... I will be at home in a couple of hours and I post the solution for u... ;-)
    it´s easy... just a line in the video_player screen...
    (ops... perhaps I should start to read all lines :-) )
  5. #4475
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question
    Hi, I was wondering how to just change color of the time and date on the main menu. I don't want to change anything else, time/date only. Is it possible? Are these setting in the skin editor? Thax.
  6. #4476
    Newbie ccwild's Avatar
    Apr 2008
    Middle GA
    Quote Originally Posted by THEREALRAWPWR View Post
    I think the easiest way to do this is to open up the 3DLogo.txt or the 2DLogo.txt in the DFX folder(whichever you are using) and find theses lines:
    L,248,140,303,27,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFo nt#,"TIME","CENTER"
    L,246,444,303,21,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFo nt#,"DATE","CENTER"
    Replace the #DFX1R#,#DFX1G#,#DFX1B# with the R,G,B values for the color you want to use.
    Here is a link I found to an online color generator which will give you the values for whatever color you need.
    www.colorschemer.com/online.html
    Hope this helps.
  7. #4477
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Anyone else having issues with IG4 not canceling the route? I press cancel and it doesnt do anything.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  8. #4478
    May 2007
    Corona, CA
    Quote Originally Posted by marteline View Post
    You quote yourself supporting you like as another person... that´s weird... (multiple personality disorder hehehe)
    Anyway,
    1- do you check the audio filetypes in RR config?
    2- Are you using the database mode or normal mode? (hold the browse button to choose between modes an see if it work)
    haha, i thought that it was someone elses post because I did a key word search and just replied to one that sounded good. There are others with the same problem but I went mine, lol. Anyways, I did enable all the audio types, I will try to switch browsing modes and let you know how it goes.
  9. #4479
    May 2007
    Thumbs up
    Great! Now I can see what time/date is without giving a hurt on the old eye balls. Thanks ccwild
  10. #4480
    Apr 2008
    Middle GA
    No Prob!
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
