Like Tree1Likes
Thread: DigitalFX 4.0
  1. #4481
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Seems that a lot of buttons dont work anymore on the IG screen. Also, the reload button doesnt work in the gas price screen. Did something change in the RR coding in the last 4 months I've been out of the CarPC hoobby?
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  2. #4482
  3. #4483
    Mar 2006
    Pennsylvania
    Yep. Downloaded after I posted that. Thanks. Works fine now. Now, to find out the other issues....
    Edit:
    Heres the other issues I just cant figure out. These buttons only work if I keep tapping them repeatedly:
    Toggle N, 3D, Cancel Route, Zooms and save location. None of these work properly in any of the IG screens. It isnt my screen either. Anyone can help?
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  4. #4484
    May 2007
    Corona, CA
    Quote Originally Posted by marteline View Post
    2- Are you using the database mode or normal mode? (hold the browse button to choose between modes an see if it work)
    Okay, I changed the browser mode and I am able to play the song only by hitting the "play selected" button. There is still no continuous play of the tracks in the folder, double tapping the song does nothing, and the next/previous buttons do nothing. All the other skins are still not working properly.
  5. #4485
    Dec 2009
    I just ran into a problem, I think somehow I ran multiple instances of RR by mistake and now my music database won't show up in DFX4.0 anymore. If I browse in normal mode the folders show up but if I switch back to database mode it doesn't. I've already done a rescan hoping it would fix the issue and nothing...any ideas?
  6. #4486
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by MrMonkeeMan View Post
    The "play selected" button is used to create a selection with the selected folders/music. When you hit this button while only a music is selected, you will create a single file playlist...
    Try to select a music folder instead a music file and then hit the "play selected"
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  7. #4487
    Mar 2006
    Pennsylvania
    Found out my problem has nothing to do with any skin. It's RR itself. So, over to RR forum.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  8. #4488
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, it was coded so that using the "play selected" button, when at the song browsing level, just plays what song song is selected. If you wanted to play the whole song list you'd have to go up one level and then "play select", causing all of the songs under that listing to be put into the playlist and played. I know this has been a mis-conception for some users, so I might look into user option(s) as to how the cmd is processed.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #4489
    Newbie TheDoctor1971's Avatar
    Dec 2009
    Now that I've finally fixed all the DFX4 skin files and added an OBD-II skin file DFX5 is sure to show up ^_^. This is still by far my favorite skin for features and usability, can't wait to see what is cooked up next.
  10. #4490
    May 2008
    Bend, OR
    mind sharing your obd-ii skin?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
