Thread: DigitalFX 4.0
  1. #4491
    Newbie TheDoctor1971's Avatar
    Dec 2009
    Sure, it uses the plugin (and is based on his carwings skin sample) from this thread. Just unrar the skin files into the dfx4 folder. The zip file has the obd-ii skin and the rest of the dfx4 skin files that needed updating like the video player fix and the skins that used the i-list that were broken. I didn't bother skinning the on screen keyboard part of the odb skin as I never use it .. so its still carwings style. One of these days maybe.
    It would be nice to see something like this built into DFX 5.
  2. #4492
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by TheDoctor1971 View Post
    Ahh, DFX 5. wouldn't it be nice...
    TruckPC - gutted, being used for test setup
    BoatPC - Update coming this spring
    BlazerPC - PS keeps killing battery
  3. #4493
    May 2008
    Bend, OR
    Haha it almost feels like one of those cheesy 1950's segments where the dad leans over to little timmy and says one day men will fly to the moon. Except insert will have DFX5.
  4. #4494
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by steven765 View Post
    Ha. I am convinced it's a marketing ploy wrapped up in an international conspiracy. Nasa wants DFX 5 to pimp out the space shuttle.
  5. #4495
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    We should use the Newbie´s as slave Labor to paint john´s car, maybe it save enought time to put him back in the DFX5...
    What about that?
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  6. #4496
    Nov 2008
    Quote Originally Posted by marteline View Post
    What about that?
    HAHA! That sounds like a great plan!
  7. #4497
    Dec 2009
    Hmm, I'm horrible at painting, that plan might backfire a bit.
  8. #4498
    May 2007
    Corona, CA
    The "play selected" button is used to create a selection with the selected folders/music. When you hit this button while only a music is selected, you will create a single file playlist...
    Try to select a music folder instead a music file and then hit the "play selected"
    Yes, it was coded so that using the "play selected" button, when at the song browsing level, just plays what song song is selected. If you wanted to play the whole song list you'd have to go up one level and then "play select", causing all of the songs under that listing to be put into the playlist and played. I know this has been a mis-conception for some users, so I might look into user option(s) as to how the cmd is processed.
    Awesome! Thanks guys!
  9. #4499
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Embedding streaming video
    Slightly off-topic but it does apply to use in this skin.
    I stream video from my house using Windows Media Encoder using a simple web interface to kick off encoding from a channel using predefined settings with various bitrates. I can then watch the video using Winamp, WMP, or Media Player Classic, and probably others.
    I want to easily start up the player from within DFX4.0. Winamp doesn't always show the video, so using it I'd have to send a key sequence to start the video window and then embed it. Could use WMP by starting and embedding it, but it's not the best choice due to size of the window. Using Media Player classic, I can start and embed it and then pass keys to it, and it should work okay. I was thinking I'd use the TV skin and reprogram the buttons to control the player.
    But since the video browser/player skin also uses Media Player Classic, I was wondering if it would be possible to pass a command to it to open a URL instead of a file and just use the video player skin to do this? The URL will always be the same. But since the bitrate will be lower I'm not sure I want it full screen.
    Any other ideas or suggestions welcome. Thanks!
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  10. #4500
    May 2008
    Bend, OR
    So this might interest this crowd. I've been trying to make a better weather interface. I think i finally succeeded.
    So been looking into doing this for a while. Someone realeased a premade tutorial on adding the embedded traffic button to google maps as it's not in the SDK, I also found someone that's publishing weather data as png. Combine the two and this is what you get:
    Lots to do, I have to add the gmap controls back, and i have a version that can take the xml lat and long from a file. So say you're driving have it point and center the map on you, with weather and traffic.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
