Like Tree1Likes
Thread: DigitalFX 4.0
  1. #4521
    May 2005
    Monterey, CA
    Same here, I have tired other skins and they are just lacking compared to DFX4. Most of them are missing a lot of features or somethings don't work as smoothly.
    FKA psptibby
  2. #4522
    Newbie TheDoctor1971's Avatar
    Dec 2009
    mnwcsult, your status is directly related to the number of posts you have. Not sure what the levels are but they'll change as your post count increases.
  3. #4523
  4. #4524
    Dec 2009
    Just read that wiki.. some amusing titles. Glad I wasn't far off base. Most forums change automatically based on post count so I assumed this one does as well. Then again, you know what happens when you assume...
    I think if I were to want a custom title it should be Lost in Time.
  5. #4525
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by TheDoctor1971 View Post
    The normal titles do change with post numbers, however there are Custom one bestowed on some by the admins occasionally.
    Oh and becareful what you asked for, as you don't normally get what you want. Have a search for Custom title elite.
  6. #4526
    Dec 2009
    What I really want is some sun and a day off to work on my truck pc. Its either got a bad PSU or a bad mobo. Maybe by the time it warms up and I get a day off, DFX5 will come out and I can make a day of it.
  7. #4527
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    Quote Originally Posted by mnwcsult View Post
    I need a skin to let me control a relay board using DX4.0. I have seen something on the Centrafuge that is along the lines on what I need here is that link http://forums.fluxmedia.net/download.../usb-relay-80/
    I have written a command line program that lets me select which relay to open or close. That was done in C++. I should/could turn it into a plugin so others could use it. I will need to read the how to create plugin thread.
    The majority of my progamming is in C++ by choice, but I write in many languages, been coding since 1973.
    What I don't have patience for is skins and graphical interfaces in general as they seem to make my eyes water.
    I disgress, my relay board is an eight channel USB device http://denkovi.com/Catalog/USBRelayB...escription.htm and my code lets me toggle each button independent of others and I need a DX4 skin with eight buttons.
    I guess I could do my on relay.skin, but would need to be jumped started to do it properly.
    Any advice/hints/tips would be useful.
    Also how do I change "newbie" under my avatar, not really a noob, just started there when I first found mp3car forums?
    Now lets get back to the central point of my earlier post. I will remain newbie
    Insight needed for a DFX4.0 skin to control a relay. Mostly just need the layout I can then add the commands I need to trigger when the buttons are pressed.
  8. #4528
    Mar 2007
    Maryland, USA
    Quote Originally Posted by JohnWPB View Post
    As mentioned, Garmin will be supported, and I also mentioned that mobile phone.net will not. Wellll..... I got around to skinning it, and it will be in the next release. Is anyone out there that has it working well and can test it? I have no way to test it here, so I can't make sure it even is working correctly I copied all of the commands that are used by the plugin, so it SHOULD work correctly, just need to verify it before I include it with the skin.
    If you want to test it, just post a reply. No PM's please, as I get enough of them already heheh.
    Here is a screen Cap of it (Again, no way to test, so all info in the skin is blank)
    This is terribly late, I do have mobilephone.net running and absolutley hate the provided skins. Would like very much to try out your new phone skin.
  9. #4529
    May 2007
    Duarte, CA
    I too would like to try out the phone skin!! and the rest of DFX5
  10. #4530
    Sep 2006
    Richmond, Tx: USA
    is there a DFX5 teaser or preview somewhere ?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
