My online status shows "offline" when online with a wireless card ... is this "normal"?
Thanks for a great skin!
Method 1. Create 3 gif graphics files, one with a play symbol (play.gif), one with a pause symbol (pause.gif)and one with a stop symbol (stop). In BottomButtons.txt file comment out the first line
/L,314,511,71,67,#DFX1R#,#DFX1G#,#DFX1B#,55,"DFXFon t1","=2","CENTER"
and add
I,298,516,97,80,"STATUS"
Not usre how well the button will work under an indicator you may need to play with it.
Method 2. Create your own font where the work Play shows a play symbol, Pause a || and Stop a Square, replace the font name for the font name (DFXFont1) in the first line of BottomButtons.txt andd change the "=2" to "STATUS".
L,314,511,71,67,#DFX1R#,#DFX1G#,#DFX1B#,55,"<Your Font Name>","STATUS","CENTER"
Method 1 you will not have the colour change, Method 2 you will.
VIA EPIA-MII12000 • M2-ATX 160W DC-DC • WinXP Pro SP3 • 1 Gb Mem • 250GB HD • Xenarc MDT-X7000 • BU-353 Weather-proof GPS Receiver • iGuidance • D-Link DWA-130 • RideRunner (08/11) • DFX4/DFX5.1
new here but I've been playing with your previous versions of this skin for a while. Is there a way to add a thirty party app that will launch like iguidance? Like I have an engine tuning program that does my logging and stuff and I would love to be able to run that inside of roadrunner through this skin so I can switch back and forth easily from navigation, movies, engine tuning. Sorry if I've missed this as I've been reading as much as possible.
I'm currently running XM on this skin and works beautiful, I'm gonna be installing Sirius on it as well. My question is, I dont have Sirius hooked up right now, so when I go and press the doggie button, road runner just hangs, doesn't display a new screen just hangs. I dont know if its because I dont have the setup hooked up.
Can you guys verify this on yours?
especially RR's FAQ'S, stickies, and search is good too.
and also this is not a thread to post every single issue you have with RR, that's what the RR threads are for. almost everything you would ever want to know has been discussed at least 20 times so search is a good tool
what was the question again?
oh yeah, here you go.
http://www.mp3car.com/vbulletin/rr-f...in-screen.html
http://www.mp3car.com/vbulletin/rr-f...cation-rr.html
How do I map other functions to buttons? can the text be changed on buttons? or can text be added to the blank buttons?
Simple, just hold the button down with finger and a list will pop up.
My carpc worklog
Whatever.......... it was a simple question..maybe too simple, I know how to go to the pre canned list of buttons but, much like the other poster above who you answered about the same, I want to use a button for something that inst on that list. and I have searched and I have read the f-ing manual and I am still asking because I didn't find a good answer in any of it.
I know I can change a button command but I thought there may be a more elegant way in this skin like in the Exectbl.ini file under "Dynamic Menu Buttons" I tried to add my app to one of those but it didn't seem to work.
Also when you go to the canned list of buttons there are "Blank" buttons, I also searched this and came up empty, can text be added and they be used to run apps that arent listed or are they just for looks if you want a blank button?
I am truly sorry brewdog if I have wasted any of your time or any of this forum space on a question that inst worthy of the space maybe when I grow up I can be perfect like you
no worries, I should of gave you an answer to go with my rant. sorry if it hasn't been answered already, I just figured it has been since I was able to do it.
I think you answered your own question though...that worked for me.make sure your window name is correct.
exectbl.ini
change the code to point to your skin& app
here:
/----------------- Dynamic Menu Buttons -----------------------
/ RR Command to execute when button is pressed
"MyApp01","AUDIO"
"MyApp02","RADIO"
"MyApp03","VIDEO"
"MyApp04","DVD"
"MyApp05","XM"
"MyApp06","SIRIUS"
"MyApp07","LOAD;freefone.skin;FreeFone;$skinpath$\ FreeFone.EXE;FreeFone"
"MyApp08","LOAD;Programs.skin"
"MyApp09","CDRIP"
"MyApp10","TV"
"MyApp11","WEATHER||RUNQ;$skinpath$Weather\Weather Downloader.exe||RELOADWEATHER"
"MyApp12","LOAD;ImageViewer.skin||Run;$RRPATH$Imag eViewer\ImageViewer.exe;ImageViewer||SETTOPMOST;Im ageViewer;true"
"MyApp13","LOAD;GAMES.skin"
"MyApp14","LOAD;GPS_Status.skin"
"MyApp15","WEB"
"MyApp16","LOAD;SETTINGS.skin"
"MyApp17",""LOAD;FreeDrive.skin||RUN;C:\Progra m Files\FreeDrive\FreeDrive.exe;Freedrive""
"MyApp18","LOAD;Mappoint_GPS.skin;Mappoint;C:\Prog ram Files\Microsoft Mappoint\Mappoint.exe;Mappoint"
"MyApp19","LOAD;StreetsTrips.skin||RUN;C:\Prog ram Files\Microsoft Streets and Trips\Streets.exe;Map - Microsoft Streets & Trips"
"MyApp20","Load;$GpsScreen$;$GPSNAME$;$GPSPATH$;$G PSNAME$||ACTIVATE;iGuidance||SENDKEY;"{p}{p}"
"MyApp21","gaspricefinder"
"MyApp22","LOAD;RRCam.skin;RRCam;$skinpath$RRCam\R RCam.exe;RRCam.exe"
"MyApp23","load;trafficcam.skin;Traffic Cam;$rrpath$Traffic Cams\Trafficams.exe;msatuev"
"MyApp24","LOAD;Rainlander.skin;Rainlander;$skinpa th$\Rainlendar\Rainlendar.exe;Rainlendar"
"MyApp25","RUN;$SKINPATH$Scripts\FindDriveLetters. exe||LOAD;AudioCopy.skin"
"MyApp26","LOAD;Color_Chooser.skin"
"MyApp27","Load;Lotto.skin||RUNQ;$SkinPath$scripts \FloridaLotto.exe"
"MyApp28","load;Internet_Radio.skin"
"MyApp29","LOAD;valentine.skin;Valentine;c:\progra m files\Software One\SoftwareOne.exe;software one"
"MyApp30","Load;Scanner.skin;RC15PRO software for Uniden BCT-15;C:\Program Files\BuTel\ARC15PRO\ARC15P.exe;RC15PRO software for Uniden BCT-15"
"MyApp31","RADIO"
"MyApp32","LOAD;Launch.skin"
"MyApp33","RUNQW;$SkinPath$Scripts\CurrentSkin.exe ||SKIN"
"MyApp34","Load;SpeedFan.skin"
"MyApp35","Load;Google_earth.skin;Google Earth;C:\Program Files\Google\Google Earth\googleearth.exe;Google Earth"
"MyApp36","Load;Lyrics_Display.skin||GetLyrics "
"MyApp37","Load;Jukebox.skin"
"MyApp38","LOAD;task_man.skin;Task Manager;;||PROCESS_LIST"
"MyApp39","Load;gmaps.skin||RUN;$skinpath$scripts\ Gmaps\gmaps.exe|2 0;gemaps"
"MyApp40","Menu;Theme_Chooser.skin"
"MyApp41","WirelessLabels||LOAD;wireless.skin;WIFI;;WiFi Information||SETTOPMOST;RR;TRUE||RUN;$SKINPATH$scr ipts\Wireless.exe||SETTOPMOST;RR;FALSE||ACTIVATE;WiFi Information"
"MyApp42","MOVIETIMES||FAVTHEATERS"
"MyApp43","RM"
"MyApp44","RUNQ;$SkinPath$Scripts\CNN-News\CNN-News.exe||Load;CNN_News.skin"
"MyApp45","Load;Daytime.skin;Daylight;$SkinPath$\S cripts\Daylight.exe;Daylight"
"MyApp46","Load;DESTINATOR_7.skin;destinator;C:\Pr ogram Files\Destinator\destinator.exe;destinator"
"MyApp47","Load;ScreenCleaner.skin"
then change you app name(label) here
These are the labels for the application that will show
/ up on the screen that gives the selection of buttons to choose from
"SetCommandLabels01","SETVAR;MyApp01LB;Music||SetCommandLabels02"
"SetCommandLabels02","SETVAR;MyApp02LB;Radio||SetCommandLabels03"
"SetCommandLabels03","SETVAR;MyApp03LB;Video||SetCommandLabels04"
"SetCommandLabels04","SETVAR;MyApp04LB;DVD||SetCom mandLabels05"
"SetCommandLabels05","SETVAR;MyApp05LB;XM||SetComm andLabels06"
"SetCommandLabels06","SETVAR;MyApp06LB;Sirius||Set CommandLabels07"
"SetCommandLabels07","SETVAR;MyApp07LB;Phone||SetC ommandLabels08"
"SetCommandLabels08","SETVAR;MyApp08LB;Utilities|| SetCommandLabels09"
"SetCommandLabels09","SETVAR;MyApp09LB;CD Ripper||SetCommandLabels10"
"SetCommandLabels10","SETVAR;MyApp10LB;TV||SetComm andLabels11"
"SetCommandLabels11","SETVAR;MyApp11LB;Weather||Se tCommandLabels12"
"SetCommandLabels12","SETVAR;MyApp12LB;Pictures||S etCommandLabels13"
"SetCommandLabels13","SETVAR;MyApp13LB;Games||SetC ommandLabels14"
"SetCommandLabels14","SETVAR;MyApp14LB;Gauges||Set CommandLabels15"
"SetCommandLabels15","SETVAR;MyApp15LB;Browser||Se tCommandLabels16"
"SetCommandLabels16","SETVAR;MyApp16LB;Settings||S etCommandLabels17"
"SetCommandLabels17","SETVAR;MyApp17LB;Destinator| |SetCommandLabels18"
"SetCommandLabels18","SETVAR;MyApp18LB;Map Point||SetCommandLabels19"
"SetCommandLabels19","SETVAR;MyApp19LB;Streets & Trips||SetCommandLabels20"
"SetCommandLabels20","SETVAR;MyApp20LB;iGuidance||SetCommandLabels21"
"SetCommandLabels21","SETVAR;MyApp21LB;Gas Prices||SetCommandLabels22"
"SetCommandLabels22","SETVAR;MyApp22LB;Camera||Set CommandLabels23"
"SetCommandLabels23","SETVAR;MyApp23LB;Traffic Cams||SetCommandLabels24"
"SetCommandLabels24","SETVAR;MyApp24LB;Calendar||S etCommandLabels25"
"SetCommandLabels25","SETVAR;MyApp25LB;Media Copy||SetCommandLabels26"
"SetCommandLabels26","SETVAR;MyApp26LB;Skin Colors||SetCommandLabels27"
"SetCommandLabels27","SETVAR;MyApp27LB;Lotto||SetC ommandLabels28"
"SetCommandLabels28","SETVAR;MyApp28LB;Net Radio||SetCommandLabels29"
"SetCommandLabels29","SETVAR;MyApp29LB;Radar||SetC ommandLabels30"
"SetCommandLabels30","SETVAR;MyApp30LB;Scanner||Se tCommandLabels31"
"SetCommandLabels31","SETVAR;MyApp31LB;HD Radio||SetCommandLabels32"
"SetCommandLabels32","SETVAR;MyApp32LB;Externa l Apps||SetCommandLabels33"
"SetCommandLabels33","SETVAR;MyApp33LB;Skins||SetCommandLabels34"
"SetCommandLabels34","SETVAR;MyApp34LB;Sys Diag||SetCommandLabels35"
"SetCommandLabels35","SETVAR;MyApp35LB;GoogleEarth ||SetCommandLabels36"
"SetCommandLabels36","SETVAR;MyApp36LB;Lyrics||Set CommandLabels37"
"SetCommandLabels37","SETVAR;MyApp37LB;Jukebox||Se tCommandLabels38"
"SetCommandLabels38","SETVAR;MyApp38LB;TaskMan||Se tCommandLabels39"
"SetCommandLabels39","SETVAR;MyApp39LB;Gmaps||SetC ommandLabels40"
"SetCommandLabels40","SETVAR;MyApp40LB;Theme||SetC ommandLabels41"
"SetCommandLabels41","SETVAR;MyApp41LB;Wireless||S etCommandLabels42"
"SetCommandLabels42","SETVAR;MyApp42LB;Movie Showtimes||SetCommandLabels43"
"SetCommandLabels43","SETVAR;MyApp43LB;RRMedia||SetCommandLabels44"
"SetCommandLabels44","SETVAR;MyApp44LB;CNN News||SetCommandLabels45"
"SetCommandLabels45","SETVAR;MyApp45LB;Daytime Map||SetCommandLabels46"
"SetCommandLabels46","SETVAR;MyApp46LB;Destina tor 7||SetCommandLabels47"
"SetCommandLabels47","SETVAR;MyApp47LB;Clean Screen||SetCommandLabels48"
anyway I think that's all I did, like I said I'm not to clear minded right now.
and you didn't waist my time, I'm just having fun, sorry if this doesn't answer your question.......and now I'm done before I offend anyone else.
Edit# sorry John, most fingers can be pointed this direction.
