Page 48 of 557 FirstFirst ... 38394041424344454647484950515253545556575898148548 ... LastLast
Results 471 to 480 of 5570
Thread: DigitalFX 4.0
  1. #471
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Does it work though? The indicator doesn't really matter if your connection works.
  2. #472
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    Quote Originally Posted by Rev1979 View Post
    Nope, always says offline when using a wireless card - on two different computers.
    Can you ping a website through that connection....the online detector uses ping to verify it's online. I ended up creating a different online detector that doesn't use ping as most of the places I use WIFI block ping. The latest version (not released yet) can be configured to work with DFX3.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  3. #473
    Jan 2008
    Texas
    Quote Originally Posted by PacketSniffer View Post
    It shouldn't matter. It's pinging an IP address. As long as you have a network adapter that can access the Internet and ping the specific address listed, it will show "Online".
    Is this what is causing the windows warning box that keeps popping up and says "cannot connect to web" or something to that effect? I thought I had a virus on my laptop when this was happening (looks like one of those hacker wanabe's with a dialer program). I just built a new system to replace the laptop in my car, fresh install of windows, RR, DFX3 and immediately started to get the same pop up's on that machine! guess I can quit scanning the laptop for viruses and such!
  4. #474
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by dmistry View Post
    This option seems like a viable fix, can anyone with font creation expertise create a font for us to try? I would give it a go but I have no skills I am just a lame end-user
    Also does this mean the change only occurs in one place or are we still editing all the skins?
    If I can find the PC that has the font editor on it I will have a look at doing it.
    And it should need (for the main part) only one file to change, but I haven't gone through all of johns .skin files to check, but knowing that the External plugins skins (like CDRip for example) do not support INC they will need to be changed manually.
  5. #475
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Enforcer View Post
    Method 1. Create 3 gif graphics files, one with a play symbol (play.gif), one with a pause symbol (pause.gif)and one with a stop symbol (stop). In BottomButtons.txt file comment out the first line
    /L,314,511,71,67,#DFX1R#,#DFX1G#,#DFX1B#,55,"DFXFon t1","=2","CENTER"
    and add
    I,298,516,97,80,"STATUS"
    Not usre how well the button will work under an indicator you may need to play with it.
    Method 2. Create your own font where the work Play shows a play symbol, Pause a || and Stop a Square, replace the font name for the font name (DFXFont1) in the first line of BottomButtons.txt andd change the "=2" to "STATUS".
    L,314,511,71,67,#DFX1R#,#DFX1G#,#DFX1B#,55,"<Your Font Name>","STATUS","CENTER"
    Method 1 you will not have the colour change, Method 2 you will.
    Couple Q's if i may: with the gif option, do you just drop the gif's in the skin forlder? and do they have to be called out in the 3rd line of the .skin file?
  6. #476
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I have only read skincommands.txt and not actually tried method 1. (not tried method 2. either but I'm sure that will work)
    But my understanding is, just drop those gif files into the skin directory.
  7. #477
    Feb 2007
    Quote Originally Posted by cirovi View Post
    - Is possible enlarge the text of the lyrics ?
    Sorry if I quote me but no idea on this ?
    AND we can also add a "scrolling" feature to the text ?
  8. #478
    Low Bitrate jjnit's Avatar
    Feb 2007
    Quote Originally Posted by jimp View Post
    If you don't like those popups (I can't stand them as they get in my way exactly as I'm trying to hit mute or something) you can disable them pretty easily if you don't mind changing a key in regedit.
    Since I hate using the touchscreen OSK more than I have to, I just use a reg file that I open from my computer - you're welcome to use it if you like. Hit the windowsxptips link here and save/open the .reg files for systray and start menu. Feel free to open to check that I'm not doing anything bad either. Or if you don't trust that, just open the file with notepad and add the dword value at the path seen.
    http://mirror.point808.com/
  9. #479
    Nov 2007
    i am using DFX3 and
    1. i dont have internet in car yet. so when i start RR the dail-up window pops as well with RR. how do i get rid of it
    2. when i exit RR for some reason and click on RR.exe again then winamp wont start till abouta minute. winap does same thing when i open it w/o RR when i exit RR. how do i get rid of this problem.
    3. whats the use of "SENSORS" in tbe RRconfig. and how can we set it up if its something useful.
    4. i am using Tay Firefly RR6 for girder. and its not working at all. i got everythign setup with gider as ive been using girder with WMP11 and worked perfectly. but unable to use it with RR. any how to around. or any one can spoon feed it to me.. lol.. as when ever i search for it i find some one explaning the last prat or some one the middel part or may be 1st part. and this is really making me confused.
    HELP ME PLEASE WITH GIRDER( most imp for me) as i cant look down to my screen everytime to change the song.
    5. when i touch in the middle on the screen I.e. where there is a logo or clock RR exits. i dont want that as it is presse accidently while turnig the visualization on.
    thanks.
  10. #480
    Jul 2006
    Well, as you approach perfection, people have to look closer to find stuff "wrong" with it!
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
