Like Tree1Likes
Thread: DigitalFX 4.0
  1. #4871
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I am with you Jebus
  2. #4872
    Nov 2008
    Yes that's terribly sad. My condolences are with you and your family.
  3. #4873
    Dec 2008
    Quote Originally Posted by JohnWPB View Post
    Custon software? It is all in there now! Just install the fusion brain and you are all set. Jebus has done the rest! All that is then needed is to put this line in the RRVoice.ini:
    Turn on the lights=DIGITALOUT1;On
    Now simply say "Turn on the lights" and it will toggle Digital out 1 relay, and poof your lights are on
    well holy crap. i need to figure out a secret 'talk' button. i was thinking about doing what you suggested months ago, and use a footswitch... but if there was a way to push that button without the passengers knowing it could be a lot of fun. just think... "lock doors" and watch their scared faces hahaha
  4. #4874
    May 2008
    Bend, OR
    Quote Originally Posted by trader007 View Post
    no no even funnier, write a script to unlock, pause and then LOCK the doors, and play the HAL 2000: "I'm sorry dave, I'm afraid I can't do that"
  5. #4875
    May 2007
    You must being just running the program with the button code, and not stating a skin for it to load into. What is happening is it is embedding into the application area in the main menu, defined for the visualizations.
    You need to put a command something like this, to load the skin, tell RR the name of the window to embed, and to run the application.
    I used the "Games_Solitaire.skin" skin in this example, as it has a full screen application area defined to test with.
    LOAD;Games_Solitaire.skin;MyWindowTitle;Full\Path to your program\MyProgram.exe;MyWindowTitle
    I tried this with the solitaire skin and the engine skin. Both seem to open the program fine except that they return the following error when I try to click on any of the program buttons:
    I have a feeling this has more to do with sawmill than with DFX 4.0, but strangely enough it works fine when it get's stuck up at the top of the screen with no skin specified (only I can't see any output). Any suggestions? The "sawmill" program comes with two different modes... a fullscreen "UMPC" mode and a windowed "laptop" mode. Both exhibit the same behavior.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at NateW.Ssm.ApplicationUI.SawMillMainForm.SawMillMai nForm_Click(Object sender, EventArgs e) in C:\Documents\Development\DotNet\Projects\SSM\SawMi ll\SawMillMainForm.cs:line 214
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
    at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
  6. #4876
    May 2007
  7. #4877
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    There are some programs that just do not like to be grabbed and embedded by other programs, I am sorry, but have no clue as to how to fix it.
    I see Sawmill has some visualization looking graphics and such, but are you mainly interested in the screen that you captured? If so there is a OBDII Plugin for RR that will display that information and more. You can display what info you want, where you want it, and how large you want it ect.
    There are even some flash gauges floating around that you can embed in the skin to display info from OBD II as well.
    My Fiero Build Thread
  8. #4878
    Dec 2008
    Quote Originally Posted by steven765 View Post
    lol my names not jerry!!!
  9. #4879
    May 2008
    Bend, OR
    hmm I don't, I don't get it.
  10. #4880
    Jul 2006
    voice activation
    John,
    can you confirm if voice will be activated by a mechanical switch, or if the system will wait for a certain command?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
