Page 49 of 557 FirstFirst ... 39404142434445464748495051525354555657585999149549 ... LastLast
Results 481 to 490 of 5570
Thread: DigitalFX 4.0
  1. #481
    Low Bitrate jjnit's Avatar
    Feb 2007
    Quote Originally Posted by monty9991 View Post
    i am using DFX3 and
    1. i dont have internet in car yet. so when i start RR the dail-up window pops as well with RR. how do i get rid of it
    Go to Control Panel/Internet Options. Choose connections tab and check the option "Never Dial a Connection", save and close. This is not really DFX related either and probably shouldn't be in this thread.
    2. when i exit RR for some reason and click on RR.exe again then winamp wont start till abouta minute. winap does same thing when i open it w/o RR when i exit RR. how do i get rid of this problem.
    I had this problem for a while too and found that it was because I had a huge (1500+ song) playlist loaded. It's a Winamp problem, not a problem with RR or DFX.
    4. i am using Tay Firefly RR6 for girder. and its not working at all. i got everythign setup with gider as ive been using girder with WMP11 and worked perfectly. but unable to use it with RR. any how to around. or any one can spoon feed it to me.. lol.. as when ever i search for it i find some one explaning the last prat or some one the middel part or may be 1st part. and this is really making me confused.
    HELP ME PLEASE WITH GIRDER( most imp for me) as i cant look down to my screen everytime to change the song.
    This thread is for DFX support - I'd recommend asking this over at the girder forum - I bet you get a bit more support, or try this thread as maybe someone already has a config that will work for you.
    5. when i touch in the middle on the screen I.e. where there is a logo or clock RR exits. i dont want that as it is presse accidently while turnig the visualization on.
    Check out this post. It is just an issue with that particular clock. Either choose another from the many options in DFX config, or if you have flash experience, edit that swf to remove the action. I personally just chose another clock as I like some of the other ones better.
  2. #482
    Dec 2006
    BROOKLYN NY
    how can i ge the lotto button to detect new york lotto not florida
  3. #483
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    Anyone here having Road Runner freeze when you press the SIRIUS SAT button? I'm using the new .skin file that fixes the sat signal strenght.
    My carpc worklog
  4. #484
    Feb 2008
    I Love DFX3 every thing that I have tried was worked thanks you all your work John
    1997 Pontiac Bonneville RIP 10/29/09
    1997 JEEP Grand Cherokee
    Software: (|||||||---) 70%
    Hardware: (|||||||---) 70%
    Car PC Install (----------) 0%
    HuntingKnightSM
  5. #485
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    Quote Originally Posted by shot598 View Post
    only works for the FL lotto.
  6. #486
    Feb 2008
    im trying to convert the rewind and fast foward buttons to change the audio stream and turn on and of subtitles the commands for media player classic are
    shift a to change the audio stream
    shift s to turn subtitles on/off
    How can i get this done please
  7. #487
    Nov 2007
    Quote Originally Posted by jjnit View Post
    thanks for the dial up problem..
    so you mean that i shudnt have too many songs in 1 playlist. as i guess i have more than 2000.
    well the problem is not with the girder, as i was using this with WMP11 already. but having prb with the gml file. i am not finiding a may be correct gml file.
    and the lclock issue is with all the clocks. not with just one. i guess there might be a hidden feature in it like minimizing.
    anywayz thanks for the help
  8. #488
    Oct 2007
    Quote Originally Posted by rgarjr View Post
    mine works great I am also using the new skin with indicators fixed and it works everytime.
  9. #489
    Apr 2007
    New Color Themes
    I tried to search this thread for themes/colors/fonts but didn't come up with anything.
    How do I get it to display the old white font (or possible another color, like yellow) instead of the 6 that come with the skin?
  10. #490
    Oct 2007
    l00kster, in the DFX theme settings under color theme I think it is it lets you set the font color.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
