Like Tree1Likes
Thread: DigitalFX 4.0
  1. #4911
    FLAC Marvin Hlavac's Avatar
    May 2005
    Quote Originally Posted by trader007 View Post
    is iguidance updated to recent maps? im running ig4 i think, i cant remember... but there are stores and bars on there that have been gone for years. otherwise, iguidance is fine for me.
    The last time I heard, the ETA for the new version of iGuidance was "late spring / early summer".
    iGuidance
  2. #4912
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Quote Originally Posted by JohnWPB View Post
    Ok, couldn't resist adding a new screen today Mitch put some code in RR that seems to finally fix the embedding of a visual, and goes from screen to screen as it should. EA: You turn on the Visual on at the top of the main menu, when you go to the audio screen the visualization will then move to and embed in the album cover area. No matter having to turn the visual on and off again to make it show up.
    He also made the code to change the transparency "live" meaning you can change the setting while the visual is running without restarting RR. So I put another option on the global options, and can change the transparency of the visual overlay with a slider.
    It's a cool initiative !
  3. #4913
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    DFX.dll and new weather screens
    In an effort to make the skin faster and more efficient than before, the skin now has a plugin, just for the DFX skin. Many of the tedious functions and code are being moved to it, and it really is speeding and cleaning things up. The Exectbl.ini that handles all the skin stuff normally, has been reduced by over 300 lines of code so far. Tony has moved all of the button chooser code for the main menu buttons into there and updated the code to work with the new way of doing it I put together. Not surprising actually, but it is so much faster how it all works now.
    One of the features I have added to it, is a weather feature I really like on my iPhone, Hourly Weather. A broad statement for the day of "20% chance of rain" does not really tell you all that much. Having an hourly breakdown, can really help you try to plan things better.
    In this example for instance, you can see that during the day in Detroit, it is fairly nice, but at around 11 o'clock at night, there are chances of rain and storms. This way, you can plan better for driving delays and such. We all know the weather forecast is never bulletproof, but this give you a lot better chances than just saying a "20% chance of rain fr the day"
    My Fiero Build Thread
  4. #4914
    Nov 2004
    St Louis
    Oooh, I likey!
  5. #4915
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    who the heck is Tony?
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  6. #4916
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by DaveDog View Post
    Sorry.... Tony=BlueZX3
  7. #4917
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Will We be able to turn off these functions one by one as in the exectbl.ini?
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  8. #4918
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    None of the stuff being moved is really an "Option". For instance the press and hold to choose what you want on the main menu, its not an option, but the way the skin works.
    For everything that could be concidered an option, there will be toggles in the global settings skin to toggle stuff on and off.
    I am not sure quite what you mean, by it being turned off really..... The ExecTbl.ini is just an extension of code to process when a button is pressed.
    For instance:
    "WeatherZoomer","RUN;$SkinPath$Scripts\WeatherLive \Weather_Zoomer.exe"
    the "WeatherZoomer" is simply a command that is fired from a button to do that function. There is no reason to need to turn it on or off....
    The only execption is the ONSKINSTART section, and that will of course remain in the ExecTbl, and can be altered and changed by the user.
  9. #4919
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Thatīs it... I was worried about the ONSKINSTART, because I always remove some things that I donīt use...
    For a while I was wondering if Tony Stark was working on DFX5...
    tks...
  10. #4920
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by marteline View Post
    tks...
    Now that would be cool, Repulsor technology to go with the iboobies
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
