Like Tree1Likes
Thread: DigitalFX 4.0
  1. #4921
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Looks like those boobies must have been upgraded as they are now iboobies... hehe
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #4922
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    All feature is welcome
  3. #4923
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    Quote Originally Posted by JohnWPB View Post
    Ok, couldn't resist adding a new screen today Mitch put some code in RR that seems to finally fix the embedding of a visual, and goes from screen to screen as it should. EA: You turn on the Visual on at the top of the main menu, when you go to the audio screen the visualization will then move to and embed in the album cover area. No matter having to turn the visual on and off again to make it show up.
    He also made the code to change the transparency "live" meaning you can change the setting while the visual is running without restarting RR. So I put another option on the global options, and can change the transparency of the visual overlay with a slider.
    So I know this is more of an RR question, but is this update to be in the July release and you just have an early edition? I setup a little vis script for my skin, but this will make it much better.
    Quote Originally Posted by treetop777 View Post
    The bar has been raised through the roof! No other front-end/skin can compare.
    I agree - great work John! I don't use your skin, but admire each function you've added.. simply amazing. If your skin would look good at 768x1024 I'd be using it.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  4. #4924
    Nov 2004
    St Louis
    Quote Originally Posted by sargeants View Post
    It can. I have a copy of DFX4 that I modified for 768x1024 that works well. Just takes some time to work out all the labels, flash boxes, aspect ratios, etc.
  5. #4925
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Getting excited, only 8 open "Bugs" left in the bug tracker
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  6. #4926
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by DaveDog View Post
    what i'm intrested in is how much faster DFX will be now most of the code is in a DLL.
    i always found DFX to be a tad slow on occassions,,,,
  7. #4927
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Important Information Re DFX5
    Quote Originally Posted by carputer1 View Post
    It loads up much quicker, but is pretty much the same while it is running. The major contributor to the speed is the skin is transparent, and for some reason RR is slower to draw screens when they are transparent, verses using .jpg's for the skin.
    Now an IMPORTANT NOTE:
    There have been a LOT of new features to RR in the past 6 months or so, even in just the last couple of releases.
    For DFX to function fully, the latest version of RR will be needed. There really is no way around this, and for the skin to move forward, it would make no sense to limit functions in the skin based on old RR versions.
    Now that RR has the ability to turn off the nag screen permanently, there really is no excuse to not use the latest version.
    My Fiero Build Thread
  8. #4928
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    good to hear , i understand the RR limitation with transparencey.....
    never the less any kind of speed improvement is a bonus
  9. #4929
    Jul 2006
    THis might be an obvious question.
    What is the upgrade process from 4 to 5?
    Will existing settings be transfered, or wi'll we need to start over?
  10. #4930
    Dec 2008
    i wouldnt even use windows upgrade as it is from xp to vista or even vista to 7.... its always best to wipe clean and start fresh, that way you know any weird problems probably wont be resolved by a format that at that point you really wouldn't want to do.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
