Like Tree1Likes
Thread: DigitalFX 4.0
  1. #4941
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question RR Update and DFX4?
    Hi, I know DFX5 is just around the bend but, I came across this slight little problem with my music info not showing on the main menu screen when I tap at top of clock area. And also when I tap visuals button on music screen album art goes away and I can't even change the visuals to the next one. I installed the newest update of RR with DFX4. I did not change anything, only updated RR. This was ok before update. Any ideas anyone?
  2. #4942
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by marteline
    John, the software used to change the bar colors, ColorPicker, can be used to change any PNG files? could you help me with that?
    Quote Originally Posted by JohnWPB View Post
    You are gonna have to get with lazy BlueZX3 on that one.
    Blue, can you help me? (I promisse that I will push John to stop call you LAZY! )
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  3. #4943
    Dec 2008
    Quote Originally Posted by Enforcer View Post
    I'm worried, I got exactly what trader007 meant.
    That worries the hell out of me.
    its ok. welcome to the dark side.
  4. #4944
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by marteline View Post
    First, I don't know if I help ppl that put words in another person's mouth.
    Second, it wasn't easy do to that for just two graphics, little alone several(lots of free time trial&error'ing?). The base color (color chosen by user) is program-ally drawn transparently over the empty bar template, then the time bubbles are transposed on top of that, then finally saved out as bar.png. Then the process is repeated for the bar pointer.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #4945
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    I was trying that before asking you, but no matter the file I selec as the empty bar transparency, the result is always in the same bar shaped...
    For example, in the attached picture, I replace "Empty Slider Bar" and "Time Bubble Overlay", choose blue in the colorpicker, but the result (bar.png in DFX folder) just overlay a bar shaped blue over my file...
    Is there a way to change the area that will be affected?
  6. #4946
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by THEREALRAWPWR View Post
    I found out that some time ago, not sure when, the settings that control the transparency of the visuals moved from the skin.ini to the rr.ini. So those that had the screensaver.ini in their RR folder, and everything worked perfectly, it stopped with newer RR releases and broke a lot of skins, DFX included.
    Put these lines in the RR.ini and hopefully that should fix it:
    PHP Code:
    AvsTransparent
    =true
    FadeOnIdle
    =false
    SecondsToFade
    =300
    FadeInterval
    =10
    DefaultOpacity
    =40
    MaxOpacity
    =200
    FYI: The next release will take care of these settings on the Global Settings screen, and you can turn the transparency on and off & adjust the transparency with a slider.
    My Fiero Build Thread
  7. #4947
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I messed with the code and have a solution that will make this process really easy and can be used by even us, should we need to add something else to the skin and won't require me to re code the one one to add it
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #4948
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    I'm looking forward to use it... Thanks Blue!
    By the way, about John´s quote in my post; BAZZINGA!
  9. #4949
    May 2007
    Thumbs up
    Thanx John, that did the trick!
  10. #4950
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Glad that did the trick, so if anyone else is having the same problem, that is the solution.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
