Like Tree1Likes
Thread: DigitalFX 4.0
  1. #5071
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Did someone just say DFX6?
    John probably just had a heart attack.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  2. #5072
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by mnwcsult View Post
    I don't know how many copies of DFX or RR have been installed, I doubt more than a few hundred. But sticking to the point a lot of R&D and time goes into great code.
    Ok, I just checked the latest stats. I have a small bit of code in the weather plugin for the skin that actually "Phone's Home" when the skin is installed.
    THIS DOES NOT GATHER ANY INFORMATION, IN ANY WAY, no personal information, no IP address ect.
    It simply loads an html web page on my server that has a php script that counts how many times the page has been loaded. This happens only once when the skin is installed, and then sets a flag to never do it again.
    I just checked the stats on that page, and as of now, the skin has been installed 14,323 times! The downloads on the DFX download page register at 14,017. The extra 300 or so times it has been installed are from completely fresh uninstalls and re-installs. Being the numbers are very close, I would imagine it is fairly accurate within a thousand or so.
    I put the code in there when I did dfx4, just to try to see how many people were installing it. Needless to say, I am floored and shocked at the totals!
    I have always been grateful for the donations, and have thanked each and every person via email when a donation is made. So thanks to all of you again.
    On the other side, if you take the total donations tallied up, and the times that the skin has been downloaded and installed, it works out to about 0.0432 cents per copy installed. (Less than a US nickel)
    Again.... back to topic This skin is going to be released FREE OF CHARGE, and if someone wants to donate, they are welcome to.
    My Fiero Build Thread
  3. #5073
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by DaveDog View Post
    Yep, he sure did... I think John said that the ETA on DFX6 is 2020, or there bouts...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #5074
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by JohnWPB View Post
    I can probably account for 50 of those. Seems like I'm always re-installing.
    Anyway, those are very surprising numbers, I am quite shocked.
  5. #5075
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Blue ZX3 spent considerable time making it Vista / Win 7 compatible with the profile mode stuff.
    The way RR has always worked is it saves ini's, settings, and all that stuff right in the programs folder. Win 7 goes about this differently and the info needs to be saved to a user/data directory for compliance.
    I know that there is at least one component of DFX that will not be supported in Win 7, and that is the Jebus plug in RRVoice. If this is installed during DFX install, I assume that one would just go into the plug in manager and turn it off? Or has anyone experimented with replacing WIN 7 sapi with 5 or 6?
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  6. #5076
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Quote Originally Posted by drewbp View Post
    I tried RRVoice with Windows 7 and I could not get it to work (I tried to install Sapi5 but it failed). I tried a few different settings but it was not compatible. Jebus stated it might work and would not be supported from his thread.
    I recently went back to XP after some other issues I experienced with Windows 7 for now until more things are worked out. Nothing with RR or DFX though...
    Gee
  7. #5077
    Constant Bitrate overlander's Avatar
    Feb 2008
    Now that RR is compatible (as far as I understand) with Itunes as the primary player, will DFX 5 also be Itunes compatible? I'd prefer Itunes to winamp if possible, but will stick to what DFX is happy with.
  8. #5078
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    If not completely itunes compatible, I believe that Winamp can add itunes music to its library also.
    i dont think the skin really cares what music player is used, if it is capable in RR.
  9. #5079
    May 2008
    Connecticut
    Windows XP
    Hey guys, just as a side note, don't know if you've seen this yet. Apparently Microsoft will be supporting XP until 2020!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! WTF!!!!!!!!!!!!!!!!!!!!!!
    http://money.cnn.com/2010/07/13/tech...s_xp/index.htm
  10. #5080
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by navputer View Post
    If RRVoice doesn't work with Win7 that will be the straw that forces me back to XP
    I understand Jebus' position, but what a limitation to his plugin that gets rave reviews.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
