Page 51 of 557 FirstFirst ... 414243444546474849505152535455565758596061101151551 ... LastLast
Results 501 to 510 of 5570
Thread: DigitalFX 4.0
  1. #501
    Jun 2002
    Virginia
    Quote Originally Posted by MAZDABOY View Post
    I got that far, but when I hold the button and select it, the box still stays blank.
    I put in
    "MyApp48","Load;C:\Program Files\DSMLink\dsmlink.exe;DSMLink"
    "SetCommandLabels48","SETVAR;MyApp48LB;DSMLink||Se tCommandLabels49"
    Did I do this correctly?
    I am not an expert, but think that it needs to load a skin file. I don't believe trying to load an executable will work.
  2. #502
    Nov 2006
    Isle of Orkney. UK
    OK, you have done what was in lines 1 and 3.
    What about line 2 ? Have you set the app label ?
  3. #503
    Apr 2005
    Ok, I tried using the destinatior7 skin and it will load, however in the main menu it still won't display the name. how do I do that?
  4. #504
    Nov 2006
    Isle of Orkney. UK
    You have added your APP to the bottom of the list.
    The next section is "PRE-SETUP-------" It is one line Ignore section
    The next section begins "SetAppLabels" At the end of that line add what you want your button to say
  5. #505
    Apr 2005
    Ok did that, but forwhatever reason RR is being finicky now. It will open but none of the words display on the main menu. And I minimize it and I can't bring it back up. It's pegging my cpu percentage to 100%
  6. #506
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    attach your exectbl.ini. I've added 3 buttons so far without any problems (MEDIALAUNCH, SNES, and OPERA)
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  7. #507
    Jan 2008
    I need help setting up PhoneControl In DFX 3.0, I know to edit the Freefone line in Menu.skin in DFX 2.5 But there is not such line in DFX 3.0. Can someone plaese tell me how to Setup DFX 3.0 for Phoco I have already configured it in RR config. I also Can connect Freefon and Phoco to my phone but I cant hear anthing through my carputer I have a motorola V195
  8. #508
    Apr 2005
    Quote Originally Posted by chevyn8 View Post
    Did that but now all of a sudden it's not responding and using 100%cpu usage. What's the fix for that?
  9. #509
    Low Bitrate lor109's Avatar
    Mar 2004
    Quote Originally Posted by itech View Post
    There is a line in Exectbl.ini inside the DFX3 Directory that needs to change to the location of the Phoco Skin. I don't have it in front of me, but I'll be more detailed later if you need.
  10. #510
    Jan 2008
    Quote Originally Posted by lor109 View Post
    Thanks I found it, but i still cannot get sound from my phone to play through the computer any help with that I have A Motorola V195, What bluetooth profile do I need to allow Phoco or Freefone complete control over my cell. I tried DUN but can dial out but no sound, when I connect using the HSF profile I can hear but I cant dial out. Please help as my phone does not support SPP
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
