Thread: DigitalFX 4.0
  1. #5101
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I do not have iGuidance set up on this computer, so overlooked it. I will add some voice commands in for it for sure
    EDIT: Ok it's in threre!
    From the main iGuidance screen (Music, tall or wide screens), you can say:
    Closest gas station
    Closest hospital
    Closest a t m
    Closest fast food
    show favorites
    take me home
    From the pop up menu, you just say what is below the buttons EA: Address, gas, Cancel ect...
    As with any of the voice commands you can change them to whatever you want. You simply go into DFX/Plugins/RRVoice and edit the RRVoice.ini.
    For instance, right now, the line to navigate to your saved home location is:
    take me home=iG_Home
    If you would rather say, "take me to my house please", you just change the line to this:
    take me to my house please=iG_Home
    It's that simple!
    My Fiero Build Thread
  2. #5102
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    John, Blue,
    few posts ago I ask about a solution to change the color of a picture... I found a software that can be very useful for you guys: "Imagemagick", with this software you can chose a color using the colorpicker and apply it on every image you want by command line or script... works great...
    I think you might want to look into it...
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  3. #5103
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    It sounds interesting, but a bit over kill I would think. At present you can put any image you want in the backgrounds folder, and choose that in the skin as wallpaper. Or choose a solid color in the color picker to use.
    If for instance you used Image Magic, to say change a landscape theme that is in the background folder, I am sure it can change the main color to another, but I doubt without a lot of fine tweaking, would get anything that you would actually want to use
  4. #5104
    Aug 2006
    Columbus, OH
    All the above sounds so good but for me sounds so sad since I'm stuck with windows 7 because all the hibernation issues I had with win xp and voice plugin from Jbus doesn't work on win 7.
    There's has to be a work around, I wonder where I should start...
  5. #5105
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by JohnWPB View Post
    Actually, I use it to change the color of the button icons, I am using a set of solid color icons and change it to the same of the font color with this software :-)
  6. #5106
    Dec 2008
    Quote Originally Posted by jarepa View Post
    qft. windows 7 is lightyears better then xp. i cant go back either because my computer might commit suicide.
  7. #5107
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    From my quick research, there is really only one way to do this, which is to use the "XP Mode" in windows 7 (basically a XP virtual machine running in win 7). Keep in mind that's only avail in Prof and above, to which you MUST be running a Genuine 7 copy. So that puts you running windows 7 only to run the SW in XP...LOL
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  8. #5108
    Dec 2008
    if it had native win7 support you would think it would be a lot easier to work with though. since vista/win7 separate each audio source it should be easy to just mute the sources you want and let the mic through, or whatever.
    ill definitely be one of those trying to get rrvoice to work in win7 though. i dont care how awesome the plugin is, even if i cant have voice commands at all, win7 is still worth every penny.
  9. #5109
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Maybe on the DT, but not worth working around all the issues in a carpc.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #5110
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by trader007 View Post
    Not to stray too far off topic but what is the advantage of running Win 7 on the Carpc? I run 7 Ultimate on 3 machines at home but use XP in the car. 7 is nice but I don't see what is to be gained from it.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
