Thread: DigitalFX 4.0
  1. #5121
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by treetop777 View Post
    A second round of tests - WHAAAAATT! <man stops holding his breath>
    LOL! This should be a quick round of tests, just to see that the installer is doing it's job, and nothing has been overlooked. I really doubt anything of signifance will turn up, as I had mentioned, the skin has been under a microscope by Blue and myself for a couple months, and the beta testers for a month. All of the issues and suggestions during that time have been taken care of and or incorporated.
    I am headed back to Frazee, MN on Thursday evening, for the First Annual Tyler Shipman Memorial Car Show. I will see what the bug tracker looks like on Monday evening when I get home.
    I will not have much internet access time while I am there, as myself, and many others, will be camping for the weekend!
    My Fiero Build Thread
  2. #5122
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    This will be a bit latter as there is just way too much going on with this skin to work out the last of the kinks, little alone doing the dfx skinning and figuring where to put it. Though, the version that is coming with the skin is a newer version.
    Will the newer version fix the audio drops to zero problem when selecting a new virtual CD?
    This one bites me in the rear a lot switching between my CD and my 11-year old daughter's, whose musical taste is MUCH different than mine.
    Thanks for the great work Blue and John and others!
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  3. #5123
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    for dfx 5 will wee be leaving dfx 4 installed?
  4. #5124
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Hmmm I don't know what is causing the volume drop issue, maybe Blue can chime in here on that one, I personally have not had that happen.
    I actually recommend leaving the current version you have installed, as they can co-exist with no problem. This way, if you have custom settings, buttons you edited ect, you can copy the code from your older DFX to the newer one.
  5. #5125
    Constant Bitrate overlander's Avatar
    Feb 2008
    Quote Originally Posted by JohnWPB View Post
    I had built a seperate page for an embedded topographic navigation program. Will I be able to copy that page over easily?
  6. #5126
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by overlander View Post
    ya, just should need the skin file and to add the code for the main menu button (if that is where you have the button to access it at).
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #5127
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Zogg View Post
    Yes, the coding has been changed as well an option to turn it off all together, so hopefully between those two options, you should be covered.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #5128
    Jun 2010
    Embedded Apps
    Has anyone had any luck embedding apps in to this skin. It is an awsome skin and would really like to continue using it. I am trying to embed Dash Command. I have done my share of coding on the web, but must admit I am having trouble wrapping my brain around this.
    Any help would be great....
  9. #5129
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by lseymour View Post
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  10. #5130
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Here. You'll get a lot more help and a lot less responses like the last one if you use search and at least show some what that you have tried to find the answer.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
