Thread: DigitalFX 4.0
  1. #5151
    Jun 2010
    Re: Dash Command
    Quote Originally Posted by drewbp View Post
    I have DashCommand in my set up. Exactly what are you having problems with? What exactly do you have working and what is not working? Have you added a button to DFX to open the program, and made a skin file to use DashCommand?
    I set up the skin file using two different versions I found on this site along with the button code which I entered DFX. It does nothing when I click the button.
    Would it be possible for you to send me the code you used for button and the skin file you used to my email?
  2. #5152
    Mar 2009
    Ya, depends on how many things carputer breaks...LOL
    can i become a tester
    thanks
  3. #5153
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    We are not taking any more testers, sorry... We have 6 now and most if not all are very seasoned RR users.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #5154
    Jun 2010
    Re: Dash Command
    Quote Originally Posted by lseymour View Post
    Ok I got it to work. I ended up copying one of the other .skins that came with DigtalFX. I have it stating directly to guages. The main screen comes up first then disapears. Is there a way to hide this main screen from being seen during launch?
  5. #5155
    Dec 2008
    well i think my carpc is finally stable. its only been a year that ive had it... ugh.
    what i did was remove my cheap trendnet pci wifi card and replaced it with a linksys pci card. then i also determined that one of my usb hubs was likely causing issues too, so i removed one and now i just use one 10-port usb hub and the rest of the stuff is plugged right into the motherboard.
    i finally have had a full week of zero issues at all. no hibernation problems, no speed or pausing issues... nothing wrong at all. dfx4 is working as it should, and its a heck of a lot of fun again.
    cant wait for 5! next weekend if all goes right i see....
  6. #5156
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Yeah I dont think I'll ever call my system stable...
    It works great for 2 weeks and then boots fully instead of coming out of standby. I attribute a lot of issues to my PCI Sound Blaster Live card on a flexible pci riser (bumps in the road dont agree) with KX drivers. I am replacing this week with an ASUS Xonar low profile. Great it's finally up to par, I think DFX5 will truly turn some heads.
  7. #5157
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    And as of current, 5.0 WILL require the August RR release. We will not be supporting any previous RR versions with 5.0.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #5158
    Dec 2008
    Quote Originally Posted by Dougw133 View Post
    i was told to try some hot glue. just squirt a bead down where the card meets the pci port. i have a flex pci card riser too, and i dont have problems except when i close the jumpseat cubby where the pc sits in. the seat hits the pc cover and flexes it a little...
  9. #5159
    Nov 2007
    PA
    Funny O havent yet, my whole car is held together by hot glue
  10. #5160
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    If the is the case...hope you don't have any really really hot days...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
