Page 52 of 557 FirstFirst ... 2424344454647484950515253545556575859606162102152552 ... LastLast
Results 511 to 520 of 5570
Thread: DigitalFX 4.0
  1. #511
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    Quote Originally Posted by MAZDABOY View Post
    Did that but now all of a sudden it's not responding and using 100%cpu usage. What's the fix for that?
    No, I meant attach your exectbl.ini for us to see. I would go back to an original exectbl.ini to make sure that is the problem...
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  2. #512
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by itech View Post
    Thanks I found it, but i still cannot get sound from my phone to play through the computer any help with that I have A Motorola V195, What bluetooth profile do I need to allow Phoco or Freefone complete control over my cell. I tried DUN but can dial out but no sound, when I connect using the HSF profile I can hear but I cant dial out. Please help as my phone does not support SPP
    Ok, honestly don't you think you would probably get better results from posting this in the Phoco thread? This is a skin thread, and is intended for issues with the skin, bugs, suggestions and such. This would be the correct place to post this, if for instance a bug, missing command or suggestion on something to add to the Phoco skin.
    I do not mean to come across as rude here, that is certainly not my intent. I have just seen so many posts over the past week about hardware & Plugin issues (Phoco, Bluetooth dongles, HDRadio, CDRip, Screenlock ect).
    If it is a bug with the skin, or a feature of a plugin is not working correctly with the skin, please, by all means, let me know
    Just an FYI, the button will be available in the next release to access Phoco as well as Freephone, and no editing of the exectbl.ini will be needed.
    My Fiero Build Thread
  3. #513
    Jul 2006
    Hi John,
    In the mean time could you provide the syntax to replace FreeFone with Phoco?
  4. #514
    Jan 2008
    Texas
    I just built a new C7 rig with a fresh install of RR, DFX3 to replace my laptop as my carputer. I started having the same problem while working on setting up the buttons, CPU 100% or close enough to cause RR to freeze. I tried everything including uninstalling and reloading RR and DFX3. I also tried other skins and found out it happened with them also. seemed to me that as soon as I tried a button that had anything to do with web access then it would lock up and go to 100% cpu. I also have DFX3 installed on my laptop and it wasn't happening to it so I copied my whole RR folder over to the car and it still was happening. the car was in the shop yesterday so I couldn't mess with it but the first thing this morning I fired it up and had to kill the RR process after a min or so then, on a whim I killed Xport and fired RR back up, idle my CPU show 10% average now (was 30%) and never goes over 50%, been running about 20 min now (never got past 1 or 2 before)
    I dont know why yet because Xport was configured right and was working, but I do know that I downloaded the latest when I built this machine so I am going to try to install the older version I have on my laptop and see if that helps.
    I don't know why but the CPU usage all showed for RR, not Xport, but killing Xport stopped RR high CPU
    Ok I never got to the point of loading the older version of Xport yet but while trying to narrow the cause down I found that when I disabled all the outputs except the main RR one, it still froze after a min or so, but now while watching the processes I notice that exec.exe keeps replicating itself every few seconds, i have several of these processes running at the same time. Although these processes don't show any cpu usage, this is when RR goes to 100%
  5. #515
    Dec 2006
    possible bug.. games are not closing upon exit of the screen
  6. #516
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by jimp View Post
    My first guess would be to check and see if you have a ziplocate.dll file in your rr folder, if you find it, delete it.
    Having several exec.exe constantly popping in and out of the process for dfx is perfectly normal as they are doing some of the backend work for the skin.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #517
    Jan 2008
    Texas
    Thats just it though, they are not just popping up, they are staying there, I have 100's running at once, of course this could be a symptom of the freeze and not a cause also . My car shut off earlier and I haven't been able to remote back in since, I am fixing to go meet the wife for dinner in a couple minutes so I will pull the old copy of Xport from my laptop when I leave. I know I have ziplocate.dll in the RR folder, but I also have it there on the laptop and it hasn't caused any problems, just the same if its unneeded I will delete if the older version of Xport doesn't do anything.
  8. #518
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Music browser?
    Here a weird one for ya.
    Just installed DFX3 on the car PC and it was working fine....for a while. Now, when I try to go to the music browser, I get this....any ideas?
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  9. #519
    Variable Bitrate BREWDOG52's Avatar
    Aug 2007
    Oregon
    Quote Originally Posted by PontiacGA View Post
    That looks pretty...does turning off ilists make any diff?
  10. #520
    Mar 2006
    Pennsylvania
    Quote Originally Posted by BREWDOG52 View Post
    Nope. I also get the 'current temp' map on the player screen.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
