Page 53 of 557 FirstFirst ... 3434445464748495051525354555657585960616263103153553 ... LastLast
Results 521 to 530 of 5570
Thread: DigitalFX 4.0
  1. #521
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by PontiacGA View Post
    Nope. I also get the 'current temp' map on the player screen.
    That would sound like rr randomly picking what to show you for your album art.
    [edit]
    Just put 3.0 in the car and I too had a weather map..
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #522
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Figured it out. I copied the rr.ini file from my test PC to my CarPC and didnt change the music directory location. Duh.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  3. #523
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Hey everyone, I first must apologize, as I am certain this is probably not the place to post this, but at the same time feel that I have to explain things as well. I will not be answering posts for the next few days, as a very close friend of mine was killed in a home invasion last night. Thank you for your understanding.
    My Fiero Build Thread
  4. #524
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    John sorry to hear that, my simpathy goes out to you and yours for your loss.
  5. #525
    Low Bitrate fixinstuff's Avatar
    Jul 2005
    Illinios
    I have previously posted that the HD Radio skin freezes up RR on my setup. After trying everyones suggestions with no luck, I decided to disect the skin line by line to see what was hanging it up. I discovered that this was the cause
    /, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed
    IL,PL,transparent.bmp,sel.bmp,end.bmp,2,50,80
    S,238,192,331,238,#DFX1R#,#DFX1G#,#DFX1B#,0,0,0,#D FX1R#,#DFX1G#,#DFX1B#,0,0,0,0,0,0,,19,"DS-Digital:B"
    Im not sure what it does but at least I can open the skin now. Of course nothing happens but at least RR doesnt freeze up.
    Instead I just started rebuilding the HD skin off of a skin that I know works.
    I know that there were a couple of others who had the same problem. Maybe this will help you find a solution.
    P.S. John sorry to hear about your loss, events like that are devasting
    Fixinstuff
    Been there, done that, replaced it with a smartphone.
    Scott AFB, IL
  6. #526
    Jul 2006
    Wow John, I can't imagine how hard that must be. Let me know if there's anything I can do.
    If anyone's interested, I resized the signal meters in the sat radio skins (XM and Sirius) and I also put the iList back in the XM skin... for some reason it was missing. I haven't verified it in the truck yet, so let me know if doesn't work right.
    Attached Files Attached Files
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
  7. #527
    Jan 2008
    Texas
    My first guess would be to check and see if you have a ziplocate.dll file in your rr folder, if you find it, delete it.
    You da man,
    that was it, I tried loading the old version of Xport and it still froze so I deleted the ziplocate.dll file and it is working like it should now. I don't even care why it is ok to have that file on one computer and not the other, as long as it works!
    Thanks, I'd have never stumbled on that going down the path I was going!
  8. #528
    Jan 2008
    Texas
    Next Problem,
    I don't get anything in the list window of the launch skin (External Apps) I can click on the slider bar beside it and move it up and down and the pictures change and I can launch the programs with the "Run Selected" button but no text appears in the list window. I had to turn the ilists off in the DFX settings to make lists show up for the logos there, I tried turning it back on to see if it helped for the external apps but it doesn't matter how I set ilists.
    Any Ideas?
  9. #529
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    Quote Originally Posted by barnyard View Post
    Thanks... Is there anyway you can check why Sirius isn't working. Maybe its something simple.
    My carpc worklog
  10. #530
    Low Bitrate erricson_nguyen's Avatar
    Feb 2007
    LA ca
    Quote Originally Posted by the_crooked_toe View Post
    only works for the FL lotto.
    open lotto .skin file in dfx 3.0 change FL to what ever your state is
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
