Like Tree1Likes
Thread: DigitalFX 4.0
  1. #5311
    Jul 2006
    You have 2 "background" entries:
    background=Z:\RideRunner\Backgrounds\Gray_Texture_ Dark.jpg
    background=C:\Program Files\Road Runner\Backgrounds\Gray_texture.jpg
    *EDIT* so do I!, so that's not the problem......
    Something in her exectbl.ini, maybe?
  2. #5312
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Hummm..looking at that screen-shot i see already what i need to hack: right-justify the text on the right hand side row of buttons.
    Need to warm-up skineditor..
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  3. #5313
    Oct 2009
    Quote Originally Posted by carputer1 View Post
    Welcome to the Carpc world and the forum ,
    you can edit the buttons as you require , in notepad , look for bottombuttons.txt these are the labels for the lower buttons,
    but you will have to edit every .skin file as john has put the button codes in every .skin file, instead of the bottombuttons.txt , i can understand why he is still going this route.
    We are here to help you get off the start line
    Thanks for the welcome, and thanks for the information. I will definitely take a look at that over the coming days.
    A couple things I noticed today:
    1. The song information doesn't always show at the top of the screen. If I go to the browser, choose a song, and play it, the information doesn't show. If I go back to the browser, chose another song and add it to the playlist, the information shows up for the song that's playing and the other song in the playlist when it's played. How do I make it show up when there's only one song in the playlist?
    2. The icons in the top bar aren't displayed when they're inactive. In the first few posts of this thread where John put up some screenshots, only the active icons are visible, but in this post, you can see how the icons are just faded out, but still visible, regardless of whether the function they represent is active or not. Any way I can get these icons to show up, too?
    3. This is more WinAmp related, I think, but hopefully you guys will know the answer. This may also become completely irrelevant when I actually get a touchscreen to use. Right now I'm just testing on a laptop with a mouse. I have a large collection of music, but rather than using playlists, I prefer to just pick whatever artist I feel like hearing and play whatever song of theirs I want to hear. Thus, the browser is the easiest way for me to quickly sift through all the artists and songs. If I pick Windows Media Player as the player in RRConfig, I can just double click on the song from the browser list and it will play. When using WinAmp, I have to add it to the playlist first, go to the playlist, and then play the song. Is WinAmp not capable of playing a song when it's double clicked?
    I really have never used WinAmp before. I would just use WMP, but with WMP, the song doesn't resume when RR is closed and reopened. With WinAmp, that feature works flawlessly. Like I said, this may be irrelevant when using a touchscreen. I'm not sure if a touchscreen can register double clicks or not. Maybe I just have to get used to adding the song to the playlist.
    Forgive me in advance for so many questions, and believe me, I'll probably have a lot over the next few weeks. I'm new to this, but I'm not new to forums, and I know how frustrating a noob can be sometimes.
  4. #5314
    Raw Wave
    Jun 2002
    Virginia
    This should work out of the box. It has always worked for me. I don't think it makes a difference for this issue, but are you using browser in standard or database mode?
    The screenshot John posted is from the still unreleased version 5.0. In version 4.0 the unused icons do not show.
    Open rrconfig. Go to Page 1 of the music section. Check "Play on list Click." See if that solves the problem.
  5. #5315
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by drewbp View Post
    Make a playlist with all 50,000 songs in it, then hit shuffle in the top left corner of the main menu screen while that playlist is playing.
    Even better: Use the DFX button editor to create a button called "Randomize". Assign the following command to that button:
    "ACTIVATE;Playlist Editor||SENDKEY;^+r||RELOADLIST","Randomize",
    Clicking this button will then sort the currently loaded playlist into random order. The advantages of this over shuffle are:
    1. If you do not have shuffle turned on you can play your playlist in random order, but still see what songs are coming up.
    2. You do not run into the repeated songs problem previously mentioned.
    Even better: John could add a randomize button to the stock button list so that those of us who think this is the best thing since sliced bread don't need to customize it.
  6. #5316
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Quote Originally Posted by treetop777 View Post
    I actually made the Left / Center / Right justify for the buttons into DFX Justify. If you change your mind later, with one edit to DFXJustify.txt you can move the button titles around.
    (/DEFINE DFXJUSTIFY "CENTER")
    L5,65,144,172,31,#DFX1R#,#DFX1G#,#DFX1B#,30,#DFXFo nt#,"BYVAR;MAINBUTTON1;$ButtonLabel$",#DFXJUSTIFY#
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  7. #5317
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by kbreeden View Post
    I don't recall seeing this this as mention in the tracker....
    This could easily be added to the release...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  8. #5318
    Raw Wave
    Jun 2002
    Virginia
    FS#145 - Randomize Playlist and Play Album Buttons?
    Attached to Project: DFX 5.0 Skin
    Opened by kbreeded (kbreeden) - Friday, 20 August 2010, 14:46 GMT (10:45 EDT)
    Actually, I posted that in the forum on the spur of the moment and then realized it would be helpful to also mention it in the tracker.
  9. #5319
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    And speaking of release.... RC2 is going to testers tonight or sometime tomorrow.....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #5320
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    My suggestion to fully implement it would be to do a DFXJustify Left Buttons and a DFXJustify Right Buttons. This way you could choose exactly how each side of buttons are placed.
    After I posted I realized what Treetop777 was really trying to do was to have the left buttons left justified and the right buttons right justified.
    Here is a proof of concept with actually 3 different text justifications from my custom menu 3 skin:
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
