Like Tree1Likes
Thread: DigitalFX 4.0
  1. #5331
    Raw Wave
    Jun 2002
    Virginia
    Both of the "Randomize" and justification of the menu's will be in the release... I did 95% of the adding of the "Randomize" to the list of avail Menu btns opts, done at lunch today... These are both very quick edits to do and so will make the RC2.
  2. #5332
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by JohnWPB View Post
    I have seen posts here and there that people do not want to use a music database, I honestly just DO NOT GET IT!
    I would imagine the music library need to be set-up a certain way to begin-with. That's where it would go haywire for me 'cause i just download a bunch of singles and put them in a folder; several different artist, several different albums, several different formats (mp3, wma, ogg), some have tags some don't, and to top it off, the folder they are in is called (in some cases) "New Folder1,2,3..etc."
    I wonder what RRMedia would do with such a mess..
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  3. #5333
    Sep 2006
    War-Town, GA.
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  4. #5334
    Raw Wave
    Jun 2002
    Virginia
    I have seen posts here and there that people do not want to use a music database, I honestly just DO NOT GET IT! There are zero disadvantages and TONS of advantages for doing so.
    +1. The database is terrific. That (by Blue) and DFX (by John and John/Blue) are the two most significant and impressive RR developments IMHO.
  5. #5335
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Wow My customization list of DFX5 keeps getting shorter.
    Thanks.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  6. #5336
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by treetop777 View Post
    (being a Limewire junkie)
  7. #5337
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The last time I checked that's not really something we're supposed to be posting about...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  8. #5338
    Oct 2009
    Quote Originally Posted by kbreeden View Post
    This should work out of the box. It has always worked for me. I don't think it makes a difference for this issue, but are you using browser in standard or database mode?
    This has been fixed. It was actually a RR limitation, up till a few weeks ago. RR would not update the song playing on the screen. Skinners used a work around for a very long time by adding a hidden playlist in screens so RR would update this info. Blue fixed this in the RR code and it is working as expected with the new RR versions.
    Hmm...quite strange. I have the 08/05/2010 release of RR, and it's not working. To answer kbreeden's question, I have the browser in standard mode. I found that the database mode doesn't allow double clicking to start the song with either player, so I put it in standard mode to allow for that. Plus, the database mode puts folder icons next to my songs, which just annoys me. I'm picky about junk like that. Then again, I'm sure if I was a software guy, I could probably figure out how to edit the icon that's showed there.
    This is something to do with the way RRMedia handled the lists, it is something Blue added in the RRMedia code to now allow double clicking to play a song in the browser to select and play it.
    Open rrconfig. Go to Page 1 of the music section. Check "Play on list Click." See if that solves the problem.
    I will try that. Thanks.
    The screenshot John posted is from the still unreleased version 5.0. In version 4.0 the unused icons do not show.
    Gotcha. Looks like I will have to upgrade to the newest version as soon as it comes out. It sounds like a lot of improvements are being made.
    Being you are a new user to RR, and to the rest of you out there as well
    I personally highly recommend Winamp as the audio player in RR. It is the most titgtly integrated player out of all of them. Some "power users" may choose to use something else for some specific reason, but I personally use Winamp, and have never had a problem, and everything works as it should. The RRMedia Database, Visualizations, and visualizations with transparency, sorting the playlist ect ect...
    Really the audio player I use for RR won't matter to me. The only reason I used WMP thus far is because of that double click thing. The most important thing to me about an audio player is the interface, but in this situation, I won't be seeing the interface, so I really don't care. If you say WinAmp is better to use with RR, I will use that.
    So another thing I found is that the flash clocks and logos don't work correctly on the second menu page. Only about a third of the true size displays, and whatever is above and below that amount of the frame is just cut off. I can take a screenshot if necessary. I haven't found a flash clock I like, so I just use the stationary logo, but I figured I'd bring it to your attention.
    By the way, when you release 5.0, can you start a new thread for it? I'm sure that I probably repeated some questions already asked, and I promise I did try searching for the answer first, but this thread has so many posts that it's hard to find anything. If a new thread is made specifically for 5.0, then people with problems or questions can post in the new thread, making it easier for everybody, IMO.
  9. #5339
    Aug 2006
    Columbus, OH
    Yes, and Winamp allows you to add this as a plugin, which tremendously enhances the sound of mp3s and gives you lots of control. I absolutely will not listen to mp3s without it.
    OMG Thank you!!! I don't how I have missed all these years that Winamp awesome enhancement...
  10. #5340
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    That is one of the VERY strong points if RRMedia. It is database driven, and not based on what folders the music is in. (Except for folder view of course) As long as your ID3 tags are correct, it will work. Actually, if you had all of your music in a SINGLE folder, you could still search by album, artist, year with no problems. Again this is all based on your ID3 tags being correct.
    For instance, if I search for the artist "Kenny Loggins" It will list all the songs in the artist "Kenny Loggins" folder, songs from the "Top Gun" sound track folder, songs from the "Footloose" soundtrack folder... you get the idea
    My Fiero Build Thread
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
