Thread: DigitalFX 4.0
  1. #5351
    May 2008
    Bend, OR
    Well if that is the case... you should not have a single mp3 file in your audio collection then as anything mp3'd, has meant that you have lost some of the audio quality in doing so.
    Yes, true audiophiles only listen to vinyl, of course stored in, and played from, a clean room to prevent any dust particles from causing any noise.
    analog F.T.W
  2. #5352
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    And u guys grunt when I ask about flac support
  3. #5353
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Dougw133 View Post
    Why do you want support for this guy?
  4. #5354
    Dec 2008
    thats a myth though. a clean cd-ripped mp3 at 320kbs is virtually indistinguishable from a cd-ripped flac or pcm file. all that dsp software does is further manipulate the original sound, and accuracy is the name of the game when you have amps and speakers that are capable of producing the sound correctly.
    if you dont have subwoofers, then programs like 'enhancer' can help because they can artificially add the lower sounds, but if you arent getting your highs like you want then you should look into better speakers and amps... and if youre going to do that, you might as well add a sub too.
    Quote Originally Posted by kbreeden View Post
    To each his own. I drive a 2005 Acura TL which came with a very good sound system and I would not even consider listening to my carputer without the plugin.
    i can assure you that sound system isnt very high quality. it might sound cool, but its not accurate. of course, its better then most factory solutions, but if you ever decide to put in a custom system you wouldnt believe the capability of real hardware. my buddy's vehicle came with an factory optional 'bose' soundsystem that he swears is amazing, and i havent told him but i think it sounds borderline awful.
  5. #5355
    Dec 2008
    Quote Originally Posted by steven765 View Post
    analog F.T.W
    cd format forever. from all the trials and formal tests ive seen, vinyl records really ARE NOT any better then cd's. and of course forget it once one speck of dust gets on there...
  6. #5356
    Constant Bitrate jeffreyd_tx's Avatar
    Sep 2006
    Wilkes-Barre, Pennsylvania, United States
    Quote Originally Posted by trader007 View Post
    Listen to your music louder... problem solved. Your ears will degrade and you will not be able to distinguish the minor attenuation on the various frequencies.
  7. #5357
    Nov 2007
    PA
    Jeeze. I should have expected enforcer to have a reference .
    Personal experience, when I compare a flac file to an mp3 on my mid to high end system it is night and day. Crisper highs and much cleaner bass. That's just me though.
  8. #5358
    Dec 2008
    i do agree, but the only stereos that i can tell the difference on are mine... on any premade boombox, factory car system or home theater in a box you just cant notice the difference. also, you if set up your own lame encoder to 320kbs constant bitrate you can get flac-like results. but when you buy from amazon or download from grey sources, they always encode to save space over keeping the quality up.
  9. #5359
    Dec 2008
    Quote Originally Posted by jeffreyd_tx View Post
    been listening to loud heavy metal for over 10 years now... and work construction. people keep telling me hearing loss is cumulative but i dont have anything significant yet. i think your ears have ways of adjusting to prolong excessive noise, up to a certain range of decibles of course. my rule of thumb is, if it makes you shutter a little bit, its too loud. otherwise, rock on.
  10. #5360
    Sep 2006
    Then your music isn't heavy enough(j/k)... rock on!
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
