One quick question about upcoming DFX5.
Will there still be need for special program for OBD like Dashcommand??
hmmm, well then, although my problem is solved in DFX5, I can not download it yet so I have to find a workaround 'til I could find a pint of pure unicorn blood?
That shouldn't be too hard?!
EDIT: I'm happy! A little change in Winamp itself gives me the full info when streaming Internet Radio and ONLY the title (instead of artist - title) when playing a MP3!
This is while using the Trackname label to display the Tag info.
next problem: When playing some Inetradio channels, the Artist and Album labels should stay blank but in the Artist field I get the URL to the stream....
Just have to figure that one out... %-)
2005 VW Passat FSI 2.0
Iceland
i like this skin DigitalFX 4.0 ~and try it this week all day~~some problem i can't fixed
1.how can i off the sound ,when i click the main button and some function button?
2.in the manu screen only buttom 1 can be use ~~another button can't even i change another function~thanks a lot
i from taiwan taichung![]()
1-You mean remove the click sound on the buttons? I don´t think that DFX 4 have any click sound...
2- Are you already update your flash? If not, open the following web with Internet Explorer:
http://get.adobe.com/br/flashplayer/
and update your flash settings...
Engineering: Where the rubber meets the road!
RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
I believe there's a skin in there for ODBII, from the ODBII plugin. However the developer stopped work on the plugin sometime last year and it has bugs from the comment's I've read over in that forum. The developer actually switched to using dash command IIRC.
Dash command has caught up and surpassed the plugin's capability to include even clearing trouble codes. So I'm thinking of going with it, Dash command is now custom skinnable so maybe someone will make a skin that uses the styling as DFX. The skin editor is free from dash command.
Here is my DashCommand skin. It is just the DashCommand default skin embedded, except for the text color change to match the DFX color I use. It does not have transparency to see the whole background, and honestly I don't know that I would want that as there is so much info to look at on the screen that a colored background would make it too hard to read.
I highly recommend DashCommand by the way. I originally was using a GTR style skin, but their new default skin gives your car gauges a completely custom look, instead of copying an existing car. By the way you can use the buttons on the left side to go to different pages, or use an iList type gesture left / right, to flip through the pages.
CAR: 2007 G35 Sport Coupe 5AT
HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
That's how I'm using my DashCommand too. Great stuff!!!
Toyota Tacoma Install
BMW 325Ci Install - Old
ZOTAC H55-ITX, Intel i3 & 320 Series SSD
7" Lilliput 669GL, M4-ATX, SB X-Fi, XMPCR
Win 7, RR, Garmin, DashCmd
Morel Elate 9 3way & IDQ10 ported (active 4-way),
JL Audio HD Amps, Audison BitOne.1
Unfortunately it takes a long time to edit the text color. It took me about 8 hours to edit their basic white to be orange, so I put it on their website so you all didnt need to do it too, at least if orange works for you. I have requested that they add a way to change the text color easily like we do with DFX, and also recently requested that maybe they make the main background transparent or at least be able to add an image. That way it will look more part of the overall design of your chosen colors and skin.
And by the way, if it took me 8 hours just to make the text orange, how long did it take Pierre L. at Palmer Performance to design and implement the whole thing. Props to him for making this available.
