Page 55 of 557 FirstFirst ... 5454647484950515253545556575859606162636465105155555 ... LastLast
Results 541 to 550 of 5570
Thread: DigitalFX 4.0
  1. #541
    Constant Bitrate funkyphil's Avatar
    Sep 2007
    CHI-TOWN
    Unhappy Omg This Goes To John
    I am deeply sorry I was just trying to be funny and make light of myself about how i just don't understand RR all that well yet. I am so sorry to hear about your friend John! and BREWDOG52 thank you very much for the heads up!!!!! I feel like a real jerk!
    Take care and again deeply sorry!
    Phil
  2. #542
    Variable Bitrate BREWDOG52's Avatar
    Aug 2007
    Oregon
    no worries Phil, no need to feel like a jerk, you didn't know.
    as for your problem, I can't really help you out, other than make sure those files are named correctly and the contents are correct..cheers
    EDIT* I just noticed that it says DFX2 in your SS, maybe create a backup and re-download a fresh copy of dfx3.
    or make sure the path to DFX3 in config is correct
  3. #543
    Nov 2007
    what does these means in the main menu " INTERIOR: N/A" and "COMPUTER:N/A" [img=http://img510.imageshack.us/img510/9767/mainmenuul4to1.th.jpg]
    how do we use these. and if i want my CPU temp there instead of one of these how can i do that.
    thanks
  4. #544
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    Quote Originally Posted by monty9991 View Post
    thanks
    this has been addressed already. read the 2nd post....
  5. #545
    Oct 2007
    Houston
    thanks
    That's exactly what "COMPUTER" does is tell you CPU temp. Actually, it might report case temp (can't remember) depending on how you have the variables set. But, at any rate, you can use SpeedFan so RoadRunner can get the variables populated.....if your motherboard is supported.
    Read the DFX Help file. It has a lot of this info in it and how to set it up. It's included on the DFX install and shows up on the DFX folder.
  6. #546
    Nov 2007
    ok.. then what does the INTERIOR means?
  7. #547
    Jun 2003
    Memphis - TN
    interior of your car maybe?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  8. #548
    Nov 2007
    Quote Originally Posted by Custommx3 View Post
    so what is suppose to be there " interior : ??? "
  9. #549
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Temperature ie degrees C or F
  10. #550
    Apr 2005
    Quote Originally Posted by john05srt4 View Post
    Mine did it also but i removed the FLASH swirling logo and its fine now.. 40-55% is normal for me now without the logo...
    It was working before with the flash logo. But anyway how do I change it if it's using all my of my cpu? The thing isn't even spinning and my pc freaks out as soon as it loads.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
