Yes, I checked into that, but I'm trying to avoid running another wire to my carputer in the trunk.
Printable View
kbreeden,
Hang for a day or so and I'll post a solution to your issue that you can test...
...JJG
Ok, for testing, give this little script a try. It is set right now for a middle mouse button click. This is easily changed in the .ini, and other examples are in there for F keys as well as left, middle and right mouse buttons.
This probably needs some error trapping and such, but is good for now for testing.
I included the source code for those that want to have a look at it, or customize to their needs.
Jebus, didn't see your post till after I posted my little script. Yours, built into the plugin I am sure would be better :)
Did you see the post above that Heather wants to send you a copy of Windows 7??
@John and Jebus,
You guys are awesome.:clap2:
I have a global mouse hook dll running right now, I'm testing and adding features. This is something that needs to be tested extensively. I am running it thru RR and making sure it does not interfere with anything else in RR.
kbreeden,
Dare I ask what OP system you are running?
Also
This thread stealing topic is moving to it's own with my next post...
...JJG
XPsp3
I agree. This thread as it relates to DFX is largely dead since it will be supplanted by a new DFX5.0 thread in a very short time; however, there has been a lot of good discussion of RRVoice in the last few days that would be a lot more helpful to others if it were in that thread instead. Please just let us know where you're going to move this discussion.
John,
I've posted a few times in the thread. I follow the thread to see what's new and just to read how to resolve problems when and if they happen on my system.
Mini Sumo Was here
Wow. I thought I was the only one that still had a functioning Smart Display. Do you have any links for additional uses? I wish it could run Android, but I'm sure it's not powerful enough for any kind of media. I also wish I could use it to easily control Windows Media Center.
