Page 556 of 558 FirstFirst ... 56456506546547548549550551552553554555556557558 LastLast
Results 5,551 to 5,560 of 5577
Like Tree1Likes
Thread: DigitalFX 4.0
  1. #5551
    Raw Wave
    Jun 2002
    Virginia
    I'm not having any hibernation issues with the Andrea mic.
  2. #5552
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Quote Originally Posted by kbreeden View Post
    Ok...thanks for the quick reply.
    Well, they sold me on this mic setup too.
    Gee
  3. #5553
    Mar 2007
    Yorktown, VA
    Embedding Streets & Trips / Button Color in DFX4
    Would someone please be so kind as to point me to instructions on getting S&T 2010 to embed in DFX, and to recolor the text on the skin buttons so they're legible? I've searched and searched, and found several posts asking the same thing and then saying "Never mind, I found it."
    When I select the S&T button in the menu, the app doesn't load at all. If it's already running behind RR, hitting the menu button embeds it but the skin buttons are an unreadbale black on dark grey.
    My S&T embeds properly in eLite, so I presume my RRconfig settings are correct.
    Thanks.
  4. #5554
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I do not have Streets & Trips 10 to test with here, so you are going to have to get the window title from the program, and put it in the ExecTbl.ini.
    Find this line:
    "GPS","LOAD;StreetsTrips.skin||RUN;C:\Program Files\Microsoft Streets and Trips\Streets.exe;Map - Microsoft Streets & Trips"
    Replace "Map - Microsoft Streets & Trips" with the title of the window for Streets & Trips 10
    Attached is a skin that should have the label colors correct
    Attached Files Attached Files
    My Fiero Build Thread
  5. #5555
    Mar 2007
    Yorktown, VA
    Quote Originally Posted by JohnWPB View Post
    Find this line:
    Aha. Turns out it's not the window name but the path that's changed. This edit does the trick:
    /"MyApp19","LOAD;StreetsTrips.skin||RUN;C:\Prog ram Files\Microsoft Streets and Trips\Streets.exe;Map - Microsoft Streets & Trips"
    "MyApp19","LOAD;StreetsTrips.skin||RUN;C:\Prog ram Files\Microsoft Streets & Trips 2010\Streets.exe;Map - Microsoft Streets & Trips"
    I suppose I could have created a symlink, but this is a better solution.
    Thanks!
  6. #5556
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    I WISH MS would make up their minds! If I remember, the same thing happened between versions 8 and version 9 with the "&" and "and" in the middle of the path name.
    Did that skin file above fix your font color issue?
  7. #5557
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    For those monitoring this thread.... All I will say, is it just may be time for a "new thread"
  8. #5558
    Oct 2007
  9. #5559
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Good bye DFX4
    Hello DFX5
  10. #5560
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    looking forward for that!
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
