Known issue to be fixed in next version.
It checks to see if there is an internet connection so that the "online" and "offline" indicators will accurately show whether you are connected.
Printable View
John, at some point you should probably change the help file to state that motionlock is now disabled in plugins.txt rather than menu.skin.
Still wrong... the next release will have a setting's menu that will allow you to turn on/off the plugins from within the skin...:)
So, without running netcheck, your online status indicator doesn't work at all? Where would you see the netcheck running? debug file?
I noticed it in task manager, it didn't look like it was hogging booka memory or anything, but RR was hanging up so I ctrl+alt+del my system and saw that running. Took a while to kill it, and once I did, all was well.
Also, it's not a flash issue causing the RR hang up, it may have been just me pushing too many buttons at once while weather was loading or something. I just saw it in Task manager, realized it was affiliated with RR (and still running after RR was closed BTW), so I wanted to check.
I might try the alternative method linked above, and see what that does.
strange.. not seeing it under my task manager.. but online status indicator works for some reason...
Ok i reprogrammed a menu button to CLEAN SCREEN.. well it locks up my CPU..
how can i reprogam a button without the touch and hold. Cause when i try it just starts the DOG lickin and i cant get out of it..
where in the INI or whatever can i change it back?
