John, at some point you should probably change the help file to state that motionlock is now disabled in plugins.txt rather than menu.skin.
Still wrong... the next release will have a setting's menu that will allow you to turn on/off the plugins from within the skin...![]()
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
dmistry,
Which power supply are you using?
Working on - 2006 Cadillac Escalade with all the TOYS!
COMPLETE! - 2002 Cadillac DTS - Summer 2008 - SOLD SUMMER 2010
COMPLETE! - 1998 Cadillac Deville Concours - Summer 2007 - SOLD SUMMER 2008
So, without running netcheck, your online status indicator doesn't work at all? Where would you see the netcheck running? debug file?
I noticed it in task manager, it didn't look like it was hogging booka memory or anything, but RR was hanging up so I ctrl+alt+del my system and saw that running. Took a while to kill it, and once I did, all was well.
Also, it's not a flash issue causing the RR hang up, it may have been just me pushing too many buttons at once while weather was loading or something. I just saw it in Task manager, realized it was affiliated with RR (and still running after RR was closed BTW), so I wanted to check.
I might try the alternative method linked above, and see what that does.
strange.. not seeing it under my task manager.. but online status indicator works for some reason...
Ok i reprogrammed a menu button to CLEAN SCREEN.. well it locks up my CPU..
how can i reprogam a button without the touch and hold. Cause when i try it just starts the DOG lickin and i cant get out of it..
where in the INI or whatever can i change it back?
10 acura TL tech
10 BMW S1000RR
