Page 64 of 557 FirstFirst ... 14545556575859606162636465666768697071727374114164 ... LastLast
Results 631 to 640 of 5570
Thread: DigitalFX 4.0
  1. #631
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Not sure id this is relevant.
    The other day I installed DigitalFX3.0 onto my C: drive at work.
    Road runner is not installed, I just wanted to check some files so I did a dummy install.##Now today AVG decided that two files had Trojans in them and cleaned them out (no idea why it didn't do it when I installed it or until now)
    the files were
    movietimesnav.exe
    albumviewer.exe
    Now whether you AV programs spot these when you download and kill them and then the installer chokes because it expects to find them and doesn't, I don't know.
  2. #632
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Wow, glad you posted that.
    On my home PC:
    OK, I deleted everything. DFX2.0, DFX3.0, and RR.
    I disabled my McAfee, reinstalled RR. But it asked me to install in Program Files/RoadRunner, not Program Files/Road<space>Runner. I changed it to Road<space>Runner.
    I then installed DFX3.0, and all works now. However, with the DFX install I noticed it asked to install into Program Files/Road Runner, not Program Files/RoadRunner/skins. I just clicked ok...it installed in C:\Program Files\Road Runner\skins.
    I also did not get anything in my "Start> All Programs" menu. I went into the folder and created desktop shortcuts for RR and RR config.
    Now...to try this on my carputer. I have no anti virus on it...different problem anyway.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  3. #633
    Jun 2004
    South-Central PA
    Ya'll think I can just copy my entire RR folder to my car PC?
    EDIT:
    Did just that, now it works...except it won't show album art
  4. #634
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Let me speak up about the installer that John is using and why it defaults to only the "Program Files\RoadRunner" instead of "Program Files\RoadRunner\Skins". The main reason is because that john tries to install eveything that the skin requires to run correctly and with using the installer, you can only tell it where you want the files to be placed From Parent install folder. So if he changes the parent path to the "Program Files\RoadRunner\Skins" then he won't be able to add/install anything one directory back.
    So now you all know why he has it setup this way and if you just leave it to install in all the "default" locations then you shouldn't have any problems. Just as a side note, I have been running RR w/ 3.0 from a "RR Testing" folder on my desktop at home and at work w/o any problems.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #635
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Blue,
    it should install to Program Files\Road Runner by default, not Program Files\RoadRunner.
    It's the space which is important.
  6. #636
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    [Edit]
    "Instruction Manual"....I don't need no stink'n Instruction Manual...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #637
  8. #638
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Boooh......I've never own a Sissymatic in my life.
  9. #639
    Jun 2004
    South-Central PA
    ... and if you just leave it to install in all the "default" locations then you shouldn't have any problems. Just as a side note, I have been running RR w/ 3.0 from a "RR Testing" folder on my desktop at home and at work w/o any problems.
    I was installing it the default way, I was not changing anything during the install, it still was getting stuck at 30%.
    I finally got it installed installed on my home pc by putting the files in the skin folder. I then copied the entire RR folder to my car PC.
  10. #640
    Low Bitrate jumbodogs's Avatar
    May 2007
    CT
    I justed installed DFX 3.0 on my home computer and I also noticed that AVG tagged albumviewer.exe as a Trojan Horse.
    Also I was wondering if anyone is using T-Mobile cell for there interntet connection. I have it setup so I can get online and browse from both IE and Firefox but I can't update weather or get CNN podcast in DFX 3.0
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
