Page 7 of 557 FirstFirst 123456789101112131415161757107507 ... LastLast
Results 61 to 70 of 5570
Thread: DigitalFX 4.0
  1. #61
    Variable Bitrate BREWDOG52's Avatar
    Aug 2007
    Oregon
    well my screen cleaning pooch is working pretty much flawlessly now, I have no idea what happened to make it work. I started working on trying to get the wireless stats to show (still can't get this to work, also advance has no effect either), the only changes I made were uninstalling my netgear utility and hooking my gps back up, right after I did this the screen cleaner started working without a hitch (doesn't make sense why this would effect that though, but no other changes were made), there is a bug though, when exiting screen cleaner by pressing menu if you immediately press the menu button again on the menu screen it will exit RR, if you wait just a second before pressing it it will go to menu2 as intended. very very minor, and I'm not nagging, just pointing out my findings, I am more than happy with DFX 3.0, and could care less if these small things are worked on. IMO you made the perfect skin for RR and it will be a challenge for anyone to top it.
  2. #62
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    OH MY GOD!!!! It's here!!!!!!
    You timed this with my Spring Break. I totally have time to upgrade and test (though I really mean play)!!!
    Ahhhhhh! asdlfkjdalskdngsanglng
  3. #63
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    The wait is always worth it. So far, no problems!!
    Is there any way to get CD art/tracks on there like the MP3 files?
    EDIT: DVD still doesnt work.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  4. #64
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    What happened to the Sat Radio option?
  5. #65
    Aug 2007
    Oregon
    click and hold down on a button ie. music,dvd, ect. this will bring up a custom button menu choose the sat radio to replace the button you held down on.
  6. #66
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by rgarjr View Post
    Sat Radio has been replaced by 2 buttons, XM and Sirius (Both available from the list of choices when you press and HOLD one of the main menu buttons). This way the code is placed on the button so the correct skin loads for the tuner that you have.
    My Fiero Build Thread
  7. #67
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Hmmm..........
    UNinstalled 3.0 and it wiped out my gdipluswrapper dll and my winamp dll, it supposed to do that? Reregistered the dll's and my other skins worked fine again.
    Thought I'd give it another go,REinstalled it, and it wiped out my whole RR install on the next uninstall!
    Seems the skin is perfectly happy to install, but gets a little PO'd when you remove it.........
    Leonardo Da Vinci
  8. #68
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    WOah! The dll's were an oversitght on my part, as then installer puts them in place and registers them to make sure they are there. I just set the uninstaller not to uninstall those files.
    As for your entire RR setup being wiped, I just cant see how that could happen. The installer only "knows" about the files it installed, and when it uninstalls, just has a list of the files that it copied in the first place, to remove.
    I really do not know what happened there.
  9. #69
    Jul 2006
    John,
    The XM signal meters still aren't there. I tried adding
    /, Y, Back Slider file path
    Y01,"slider_battery\slider_*.gif"
    to xm.skin, just above the two signal lines. It works, but it also uses the same "image" for the station list slider. Is there any way to separate the two slider types?
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
  10. #70
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Not to break it up, Quick question though. I understand for the Cover Art Browser there needs to be a JPG in the Root Folder. I only have Album art in the albums themselves. Is there ony other way than "one by one" to have something automatically copy/pull a file to the root folder as well? Thanks...
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
