Page 71 of 557 FirstFirst ... 21616263646566676869707172737475767778798081121171 ... LastLast
Results 701 to 710 of 5570
Thread: DigitalFX 4.0
  1. #701
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by BlackStealth View Post
    It's not iGuidance, but Garmin (new PC software about to be released in a few days). Lookout iGuidance!
    Other than the software is Navteq which is the same thing Iguidance uses.
  2. #702
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    Quote Originally Posted by funkyphil View Post
    Hey guys, got a few quick questions. I just installed my Iguidance 4.0 and seems to be working ok, however got a few problems.
    1. Everytime I go an click on the icon for GPS it opens GPS MAP but it is not sized correctly in DFX SKIN. I kinda thought it would be FIXED inside of the GPS PAGE. (Kinda like how when you click on music or photos or the web nothing moves just stays in one place.) So if i click by mistake just below the map window, the map window disapears and i have to reload rr all over again. John, I watched your video and in the video you say if you save the screen even if you get out of it, It will still be the same as you set it. But it doesn't stay. Did I miss something?
    2. And when I click on gas prices, weather, and gauges, nothing works. Example, Gas prices will only find the nearest gas station if i put in the zip code. (WHAT IF I AM SOMEWHERE I DON'T KNOW THE ZIP RIGHT? LOL) Gauges, the compass on the gauges does nothing other then read NORTH all the time. do i need so set something for the GPS to correct this? WEATHER, at the top right of the weather, it reads GPS Weather, does this change on location of the car? I will be driving to TX in two weeks and was wondering if this would change as I drive?
    Thanks if anyone can answer these questions that would be very cool!
    Thanks again
    Phil
    1. how is it not sized correctly? can we get a screenshot. Also, John has included many different options to fit iGuidance into your screen to your liking. There is an indicator on the GPS page. Have you set Iguidance to native in RRConfig?
    2. are you using XPORT or GPSGate to split your GPS ports? are the GPS ports lower than 9? make sure you are not using the same GPS port for both RR and iGuidance.
  3. #703
    Jul 2007
    Louisville, KY
    Quote Originally Posted by lewcamino View Post
    I am still reading (Page 26) but I searched on this with no luck.
    I use RDP (Remote Desktop) to configure my carpc from inside. DFX 2.0 was just fine with this but 3.0 makes it very difficult.
    For instance, music browser does not display anything in the list (unless I turn iLists off). However, jukebox does nto display anything with iLists on and when I turn them off and access jukebox roadrunner freezes.
    Any ideas on how I can get this to work with RDP. I love to setup and test everything that way.
    Thanks, Lew
    how about you go test inside the car now. then that will let you know that it will not work using RDP. I would use VNC if i were you. www.realvnc.com
  4. #704
    Jun 2007
    Quote Originally Posted by the_crooked_toe View Post
    Good catch on that, I forgot who we were dealing with for a second there. Better post links to both while you're at it.
  5. #705
    Jul 2007
    Louisville, KY
    Quote Originally Posted by duyusa View Post
    I downloaded the skin
    But I got some problem with the interface. The skin appears almost in white, when I move the mouse around, it start coloring the part (revealing the true color of the skin). when I click mouse it appear a red ball. When I move mouse and keep clicking it, the red ball mouse with the mouse pointer slowly with a long tail.
    Why really happens here? Any ideas?
    update flash using Internet Explorer.
  6. #706
    Jul 2007
    Louisville, KY
    Quote Originally Posted by kostas_lion View Post
    hello i want to ask you 3 questions
    1. how can change the font style ?
    2. how can rename to translate to greece title of the bottoms?
    3. how can work the roadrunner digitalfx 3 with my voice???
    thanks.
    1. No, it's John's font.
    2. Good luck. I believe it's english only
    3. research, research, research
  7. #707
    Variable Bitrate BREWDOG52's Avatar
    Aug 2007
    Oregon
    make sure your background pics path is correct, can change in the config or ini...ie...C:\Program Files\Road Runner\skins\DigitalFX 3.0\DFXBACKGROUNDS
    PEOPLE... YOU REALLY NEED TO READ JOHN'S HELP FILE AND SEARCH THE THREADS. The last few questions posted here are some of the most common problems (easily found if you would just look)
  8. #708
    Aug 2007
    Oregon
    Thanks again
    Phil
    Like crooked toe said..you need a com port splitter (xport or gps gate...xport is free)...make sure you assign a port for each app that uses your gps, then setup your app to use that port..make sure IG4 is set to a port lower than 9...if you need more help on this just search for xport..or gpsgate if you will use that.
    I believe gpsweather will gather the info directly from your gps unit instead of the internet.. your gps has to be compatible to use the gps weather...I don't know what models support this...do some research on your gps unit to see if it will support weather.
    thanks.
    3. heres a good place to start
    http://www.mp3car.com/vbulletin/rr-p...ontrol-rr.html
  9. #709
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    But I got some problem with the interface. The skin appears almost in white, when I move the mouse around, it start coloring the part (revealing the true color of the skin). [HL]when I click mouse it appear a red ball. When I move mouse and keep clicking it, the red ball mouse with the mouse pointer slowly with a long tail.[/HL]
    Don't know how crooked toe missed this one?? Is he becoming derilict in his duties?
  10. #710
    Aug 2007
    Oregon
    Quote Originally Posted by treetop777 View Post
    machinehead beat him to it.....http://www.mp3car.com/vbulletin/1195671-post700.html
    edit* oh now I get it....he forgot to add ....
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
