Page 75 of 557 FirstFirst ... 25656667686970717273747576777879808182838485125175 ... LastLast
Results 741 to 750 of 5570
Thread: DigitalFX 4.0
  1. #741
    Newbie BlazingBird's Avatar
    Feb 2008
    RR and DigitalFX 3.0
    I have am having a few issues with digitalfx 3.0. I would like to get my sirius satellite working with this skin, is it possible. Also I have the skin freeze on me, and close unexpectingly. I REALLY like this skin, so please somone help. It is greatly appreciated.
    Thanks,
    Wes,
  2. #742
    Feb 2008
    I Need Sirius Help
    I just downloaded the skin this morning digitalFX 3.0? Is that the new version? I would sure appreciate it if you could give me a walkthrough on how to get sirius to work with this skin. It really like it.Thanks in advance.
    Wes,
  3. #743
    Variable Bitrate BREWDOG52's Avatar
    Aug 2007
    Oregon
    Quote Originally Posted by silvi4000 View Post
    Havent checked the implementation but Im pretty sure GPS weather means it will pull weather based on your coordinates. Most likely somewhere the coordinates are translated to a zip code and then the weather is queried based on zip code. You will still need an internet connection to get the weather.
    All GPS provide is coordinates and time synchronization (im not sure how that time part works), but not weather info
    your right, I haven't looked at the weather page to much since I don't use it...I thought it would automatically go to your current location. sorry if I confused some people.
  4. #744
    Aug 2007
    Oregon
    depends what gps receiver you have....here is one that will display weather. the weather info is not coming from the same satellites..
    .but it is a gps receiver
    http://tech.yahoo.com/blogs/raskin/7163
    Edit* didn't mean to double post
  5. #745
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by tundra2000 View Post
    idn if anyones commented yet, but latitude has one 'T' i think. not lattitude. thats on the gps_status.skin
    It's because this skin has attitude.
  6. #746
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    I searched for the problem but could not find anything simillar. I think it is skin related so I am posting here but if that is not so, please let me know.
    I am running RR with DigitalFX 3.0, and iGuidance 3.0. Everything runs beautiful except for the "guages". So I downloaded Xport and splitted com port 7, where my GPS was connected to, to com ports 8 and 9. iGuidance is now configured to port 8, and RR is configured to port 9. The problem I am having is that everything runs well until I open the Guages skin. The guages work for about 20 or 30 seconds and then RR hangs and I have to close and restart it. I tried many different combinations of the com ports and all seem to yield the same results. If I don't go to the guages skin, RR seems to not hang. I don't realy know what may be causing this, RR, Skin, or Xport? BTW, the PC does not freeze. Only RR hangs.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  7. #747
    Oct 2007
    Quote Originally Posted by Zebelkhan View Post
    Sounds like it could be a flash related problem, are you running the latest flash? If not use IE (not firefox) go to http://www.adobe.com and install the latest flash version.
    EDIT: I am assuming you are not running flash clocks or anything.. but if that stuff works then i dunno
  8. #748
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by dmistry View Post
    I am running a clock on the main screen and it works fine (until everything hangs of course, or ran fine before I decided to get my guages working) so I doubt it is flash related but just to rule it out, I wil remove the clock and try to see if it works that way.
  9. #749
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by funkyphil View Post
    John,
    I know your not being rude, but you have to understand one thing, It is one thing to read the manual (and I did indeed read it) But it's another thing to understand it.
    I totally understand where you are coming from. That, honestly, is why I decided to do the help manual with the skin.
    In the first part of your question, you asked why iGuidance was not embedding, and why it disappeared when you press a button.
    In the help file it states in the GPS-iGuidance section:
    "You need to set it correctly in RRConfig to allow it to launch and embed correctly. Below is what your settings should look when iGuidance is configured correctly:"
    and below that there is a screen capture of the config utility showing the exact settings, and what goes in what box.
    I honestly just do not know how to make it much easier than that I did my best to write that help manual, for the new user / non programmer.
    My Fiero Build Thread
  10. #750
    Constant Bitrate funkyphil's Avatar
    Sep 2007
    CHI-TOWN
    Thank you John,
    That helps and You are doing a wonderful job at this skin. I am a newbi but by far no matter how many times i fall i am going to get up and try again. I love how this works and very thankful for all you have done!!!
    Thanks again
    Phil
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
