Radio and HD radio both use the same skin. What tuner are you using?
I have most things running correctly, but have a problem with the radio.
The RADIO button brings up the HD-RADIO skin. There are ini files for both, but the only on/off png's I can find are for HD.
In the Radio Standard folder is the ini and png's for I presume version 2.
I have tried to use these but that only suceeded in closing Road Runner when selected.
As I cannot find it mentioned in any other thread, if I am the only one then I must be missing some files. I have downloaded DFX again, on another machine as well, but the result is the same.
Can anyone suggest a workaround?![]()
MSI K9N6GM
1 gig RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
I'm using a D/link USB controlled by Radiator.
When I select the Radio button it starts the Radiator programme and the radio works.
Unfortunately none of the buttons on the skin will function.
I could be wrong, but I don't think you need to use radiator... set up radiomode=1 in rr.ini and see what that does
MSI K9N6GM
1 gig RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
OK, I will give that a try tomorrow.
Bit late now, just after midnight.
Many thanks
Please help me with why I keep getting this error. Here is the link where this thread is. thank you
Phil
Need Help Setting Up Xport Please!
Tried as above, result -- nothing worked.
It looks as though I need Radiator to control the radio. The problem remains getting the skin and Radiator to talk to each other.
For the present I have set up Radiator as an external application. Not ideal I admit, but at least I can control the radio from within the skin.
Hi Guys,
I was hoping that maybe someone has a fix for this error i keep getting. Here is the link from a different thread I have posted!
Thanks in advance.
http://www.mp3car.com/vbulletin/gps/...-new-post.html
just a note.. when i uninstalled this (it has so much stuff ill never use) some how it either removed or crippled Comdlg32.ocx, and as a result i could not get the skin editor to work. reinstalling this skin didnt fix it, so i tracked down Comdlg32.ocx and reinstalled that and its all good again..
