John, I finally got everything going and the skin "Kicks ***", Of course its just my luck that you don't have Infinty listed as one of your logos
These are better ideas IMO because JUNK would be posted in the subforum just like it is being done here.
What is really needed here is somebody (qualified) to police the place agressively..< is that spelled right?
EDIT: There is also a (so far unpopulated) Wiki for DFX.
Thanks dmistry, i knew it didn't look right.![]()
New Problem.
I have had the skin up and running great. I have recently picked through this thread to do a few minor fixes etc. One being getting the WIFI Manager to display the stats correctly in the skin, and the fix listed worked fine. My problem is that all of a sudden the while RR is running, even though I have "Hide Mouse" selected, it flashes on top of the skin every 3-4 seconds. If you minimize RR it does the same think on the desk top. The hour glass seems to flash with the mouse arrow every few seconds. The only apps running are RR and netcheck. Now I have 36 processes running. Anyone else having this problem?
The netcheck is removed from the next release, and probably the reason you are getting that is from the backend scripts that make DFX work the way it does. But I pretty sure that you shouldn't be getting that every few seconds... you would need to list some more details as that is all that I can tell you from what you've posted. Like, do you see any say exec.exe process popping in and out of your process list?
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Well, after some more fidling around, it seems to go away when I manually close the WIFI manager in the task manager...?
Okay I know I am missing something. I have searched not only in this thread but in the forums as a whole. My problem is that I cant get the zip code with gps to populate the gas prices or the city, town, county, zips info. I have zips.dat in the road runner folder, and even replaced it with a different one as it was 0 kb under properties. It tried putting the states.dat from the zip code folder into the root folder and that didn't work. I read in the 2.0 forum that there should be a larger version of road runner.exe with the dfx install but can't seem to find it, and my road runner.exe is only 650kb not the 2gb special version mentioned.
Please help. I have worked through most other issues that affect me at the moment, but this one is a stumper for me.
P.S. I have xport running. I have satellite info in iguidance and on the gauges screen.
Things to check; Do the zip code locations work in the gps screen and the gauges screen? Do you have a working internet connection?
Edit: There is also a setting that needs to be set in the RRconfig file.
