Page 81 of 557 FirstFirst ... 31717273747576777879808182838485868788899091131181 ... LastLast
Results 801 to 810 of 5570
Thread: DigitalFX 4.0
  1. #801
    Newbie japeeler's Avatar
    Nov 2007
    Jefferson, Texas
    Drewbp:
    I was having the same issues. I am not absolutely sure what the entire issue is, BUT, I changed to my next town ZipCode manually that ias bigger than my 3 stoplight town.. LOL.. (Laughing at the size of my town decription.. really is 3 lights big!) We have approx. 5 Gas Stations here. They will NOT show up if I just choose my zipcode. I was having this same issue, and even posted in previous 100+ pages ago.
    No fix for it, that i could tell. I can get it through my Data/Cell and WiFi connections just fine for any other town but NOT my own, which the ZIP.DAT files does have my town zip in it and I can see it on the msn-auto website, etc...
    I know this is not a "FIX" answer, but try: goggle a town with this: name of town/city, state zipcode (Physically type in "ZIPCODE" word to look up zipcodes. Copy/Past a zipcode and try to see if GasFinder updates.
    (ie. Marshall, Texas zipcode )
    This should help see if the plugin is workign or not, etc...
    JP
    -=- TruckPC Progress -=- 98% Complete -=-
    -=- 2006 Ford F-150 Screw 4x4 -=-
    @@@@@@@@@@ <-- Planning Phase
    @@@@@@@@@@ <-- Purchasing (Never End)
    @@@@@@@@@@ <-- Construction Phase
    @@@@@@@@@@ <-- Installation Phase
    My TruckPC WorkLog @ MP3Car.com
  2. #802
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Quote Originally Posted by Machinehead View Post
    Things to check; Do the zip code locations work in the gps screen and the gauges screen? Do you have a working internet connection?
    Edit: There is also a setting that needs to be set in the RRconfig file.
    None of the city state county zips fill in on any screen from gps. Gas price plug in works fine when I manally put in a zip code, but once again not from gps. I know that I have gps data feeding the gauges screen and iGuidance through xport, and I have an internet connection, and I have set localdatacaptureinterval=1.
  3. #803
    Aug 2006
    Can someone tell me what is the Jukebox for? , is it like a pandora.com service?. I dont get anything out of it, I have Verizon Broadband, when I do a search I see some activity on the modem, but I dont get any results...is there any documentation?
    Mar 2006
    Blog Entries
    1
    Quote Originally Posted by greatwhite View Post
    Another post for clicking on the clock in main screen causes RR to exit..............
    I had the same thing happen if you click rapidly below the clock. What I discovered is that the "exit menu" is somehow being called and the exit selection can be accidentally selected. This event can happen so fast that you won't even see an exit screen if you click twice rapidly.
    I've scanned over the menu.skin and cannot find any mistakes. I even downloaded skineditor to comb through it but no mistake can be found.
    EDIT Quick fix: By replacing the spinninglogo.swf with another flash file such as _Clock_Round_Transparent_Orange.swf the problem goes away completely.
  5. #805
    Dec 2007
    Quote Originally Posted by Dougw133 View Post
    Well, after some more fidling around, it seems to go away when I manually close the WIFI manager in the task manager...?
    why don't you run manager on button click and close it on exit instead of having it run all the time from startup...
    I've seen that problem too, little annoying... So, that's how I deal with mouse flickering...
    By the way, in task manger, is there a way to show cpu percentage as well... i need to identify which process is sucking up all my CPU... With current view, i know cpu says 100% but can't tell which one is stealing all my cpu...
  6. #806
    Oct 2007
    Houston
    Quote Originally Posted by brandensin View Post
    While looking at the Processes tab in Task Manager, toggle the column label for CPU. It will sort by highest utilization first.
  7. #807
    May 2006
    Chicago
    Quote Originally Posted by lewcamino View Post
    In the video player I would like the |<< & >>| to go to the previous and next video. I have edited the skin so those buttons are "PREVTRACK" & "NEXTTRACK".
    PREVTRACK works okay, but NEXTTRACK still just skips ahead in the currently playing video.
    Anyone else?
    ^ Help with this please?
  8. #808
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well I just tried those commands in my iDrive skin, and they do exactly what they say on the tin.
    if you have edited the skin make sure you have done the right .skin file, done it in the right place and got the format and wording correct.
    if all that is OK, check the exectbl.ini to see if NEXTTRACK has been changed in there to do something else.
    *edit just check DFX on my PC, and in the Exectbl.ini there is the following line
    "NEXTTRACK","NEXT||ChangeStarIndicator"
    so yes john has changed NEXTTRACK for something to do with ratings I guess. So you can either delete that line in which case whatever john changed it for will not work in another screen.
    *edit2 maybe just change it to
    "NEXTTRACK","NEXTTRACK||ChangeStarIndicator"
  9. #809
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    Quote Originally Posted by filatelico View Post
    This is a feature John has added. The project itself is in Beta. Its basically this simple. Type in a song name, click on download. It will download the song to a Downloaded Songs folder that can be found on the Browser within the skin. I would only try to get *popular* songs.
  10. #810
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Got my problem solved.....or the computer did by itself.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
