Page 86 of 557 FirstFirst ... 36767778798081828384858687888990919293949596136186 ... LastLast
Results 851 to 860 of 5570
Thread: DigitalFX 4.0
  1. #851
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by aerotight31 View Post
    Where exactly do I need to go to make those changes? I couldn't figure out how to do it with the skin editor, and I'm not sure which file to open in notepad. I tried opening ExecTBL.ini, but I'm not sure that's right either. Thank you for any help!
    *update* I found this line under the virtual skin editor. Is this what needs to be edited (i.e, Prevtrack to "up" & Nexttrack to "down")?
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B90,0,518,101,81,"LOAD;menu2.skin",""
    B09,100,517,99,81,"EXITMENU",""
    B,198,517,97,81,"PREVTRACK",
    B,295,517,100,81,"PLAY",@STOP||PLAY@
    B,398,519,98,79,"NEXTTRACK",
    B11,497,519,102,79,"VOL-",""
    B12,597,519,98,79,"VOL+",""
    Look at post 807
  2. #852
    Jan 2008
    Quote Originally Posted by treetop777 View Post
    Look at post 807
    Well, apparently, I'm an idiot. I still can't get it working. I'm not sure that post 807 really helped, either. Now, since I've been trying to fix it, I've screwed something else up. Now all my buttons along the bottom are REALLY large numbers, instead of symbols. Don't know how I did that, or how to fix it. I'm guessing, though, it is probably in the same place I need to be to fix the next and previous buttons. HELP!!!!
  3. #853
    Sep 2006
    War-Town, GA.
    Reinstall DFX3, you probably did mess up the line that defines the font. After that, go to that line you found (if it's in the right screen) and change it the way you said:
    prevtrack=up; nextrack=down (or viceversa).
  4. #854
    Jan 2008
    Okay, downloading DFX fixed the newest problem. I needed to download the RR Skin Editor here on my work computer, so that could get back to the lines I need to edit, but the link isn't working. I was in the virtual editor. I have it at home, so I'll have to wait until I get home and try editing those lines then. That is unless someone has an alternate link to the download. Thanks for the help!
    *EDIT* Fixed it!!! I changed PREVTRACK to down and NEXTTRACK to up in the video_browser and video_player skin files. Seems to work perfect now! Thanks for all the help and suggestions!!!!
  5. #855
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    I am trying to get 2 programs to open up with the touch of one button. I have made a custom skin that I want Iguidance to open on the left and IE7 on the right. I can get one or the other to open but not both together. And how do I assign a specific program to each window since they are both A window.
    Is this the right place to ask or is this more of a RR question. I have searched and cant find. Thanks.
  6. #856
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You can only have one application per screen/skin unless you use a third party app like skinbedder.
  7. #857
    Low Bitrate leatherboy's Avatar
    Mar 2005
    Athens, Greece
    At last, I just finish reading 57 pages of posts. Few.
    John, you surely do a great job and you surely give us a lot of changes with your skins. Thanks.
    I worked with DFX2 from the first time you published it. I did many tweeks and I am absolutely satisfied. With DFX3 I have some problems but after all this reading I noticed some possible solutions and I will try them in time. I have a recommendation if you allow me.
    When I saw the lyrics option in DFX3, I fixed almost all of my song's tags and now I am happy to see it working. But I think I will be great if you fix the program that displays the lyrics to delete the empty lines. So most of the words will be in one screen and there will be no need to scroll down. Another option that could be very usefull is the "karaoke" display. I mean that the text could scroll down depending on the time or something. I found a very interesting small program, minilyrics is the name, and i think you should check it to see how this "karaoke" works.
    Thanks again.
  8. #858
    Constant Bitrate djchicago's Avatar
    Chicago Ill
    Nice HD
  9. #859
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by leatherboy View Post
    Ask and you shall receive I just edited the script to remove blank lines from the lyrics display.
    As for the karaoke, there is no real way to do this keeping the look of the skin. It would involve having to embed mini lyrics, which is also not a free program. Personally I would be scared to death to know someone else on the road with me was trying to sing karaoke while driving
    My Fiero Build Thread
  10. #860
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    I dont know if taking out the blank lines is something you want...
    sorry, but that messes with the way the lyrics were written. Maybe its called iambic pentameter but i'm not positive. I say if we can get iLists to work on the lyrics screen and be able to remove the line with the cursor that seems to cover up a line when your scrolling, then problem solved.
    i had my g.f in the car with me the other day and she said something about having the lyrics scroll with the music. i then tried to explain to her how much time and effort it would take to make that work...especially with people that have over 25,000 songs.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
