Page 88 of 557 FirstFirst ... 38787980818283848586878889909192939495969798138188 ... LastLast
Results 871 to 880 of 5570
Thread: DigitalFX 4.0
  1. #871
    Low Bitrate leatherboy's Avatar
    Mar 2005
    Athens, Greece
    Quote Originally Posted by JohnWPB View Post
    Hmmm Not sure what that command in the last line of the debug file is coming from:
    17/4/2008 10:00:47 đ́: Sim.WMSGs: 1
    Are you using PowerStrip by chance for multiple monitor support? I ask this as searching for that last command above in Google, I found THIS thread. Not sure if it will be of much help, but its worth a look.
    The "Sim.WMSGs" command looks like it could be coming from another plugin, not sure. Try disabling all plugins, and see if RR works ok. If so re-enable one at a time and see if you can find what is causing it.
    No John. I never tried somothing like that. I mean Powerstrip. I spent 2 hours in my car today trying different configurations. I had no luck. I installed both new versions of RR and DFX3 at the same time. Is there a possibility that one of these programs have changed the way that uses the GPS and that's the reason that now I have the problem that I didn't before?
  2. #872
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    FYI to All:
    The "Sim.WMSGs" is a completely normal line to see in the debug. What this tells you is that one more or more apps are sending rr a window message at the same. I asked the Man about those lines some time ago, because I was curious what they stood for. He had also said that 1-4 was a normal range, it when you see more larger than 4 is when you might start to see problems...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #873
    Newbie k1hog's Avatar
    Oct 2007
    JohnWPB, Is it possible to load the navigation program Co Pilot from within DigitalFX 3.0?
    Thanks Johnnie
  4. #874
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon
    Ok, silly question I know, but I really don't want to search all over for this answer. I've set up a button controller (iMon Ultrabay) for Streetdeck and it works great. Now I want to try doing the same thing for DFX 3.0. Is there a keystroke map somewhere for the module selection without having to go into the code?
    My opinion is my own.
  5. #875
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The file your looking for is the "KeyTbl.ini" in the Road Runner folder. It defines keys and what function is associated with it. Depending on what your trying to do, you might have to continue that function into the exectbl.ini file to allow you to put several rr cmds to one function.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #876
    Sep 2007
    Beaverton, Oregon
    Thanks,
    I figured it out. Only thing I still don't have is the actual command for rewind 5 seconds. Fast forward is FFWD (obvious), but rewind isn't REW or RWD. Is there a command that calls the main menu? Tried MENU, but that didn't work.
  7. #877
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    try main for the main menu.
    also have a read of skincommands.txt (it should be in the root of your roadrunner/roar runner folder.)
  8. #878
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by danielkh View Post
    Thanks,
    Try "PREV" and "MAIN"
  9. #879
    Sep 2007
    Beaverton, Oregon
    Quote Originally Posted by Enforcer View Post
    Excellent! Thanks! Only have 10 buttons to worry about, but that skincommands gave me the last one I needed (FRWD).
    ________________________________
    So far, the iMon Ultrabay is extremely impressive with RR Digital FX. It knows and displays song info (MP3's), equalizer, and on internet radio, it knows and displays station, ip, song, artist, (album I think). Internet radio also sounds really good! It doesn't know XM, and when navigation starts (iGuidance), it "loses" it's place and doesn't know where RR is. In other words, once navigation starts, the iMon buttons quit working until you touch some button on RR. It also knows when CNN is playing and when the last update was (readout shows CNN update xx/xx at xx:xx).
  10. #880
    Constant Bitrate mpfjr's Avatar
    Jun 2004
    Corona, CA
    Finally got around to installing DFX3.0 and so far it is truly amazing!
    I could sure use some help with a few things. I did a search but I must have searched for the wrong keywords so if you could point me in the right direction I'll read it for myself.
    First thing. I checked out the "themes" and picked the emerald green theme. However after that I decided to go back to my old DFX2.0 look and no matter what I do it stays as that theme. I used to have the blue coral back ground with the dodge icon with the analog clock around it. I can get the clock part to work but the menu itself is still that theme and not the background walpaper or the other things I can choose under settings.
    Second thing. In the first post there is a screen shot showing some sort of visualization and the caption says "menu with visualization enabled" What must I do to get my menu to display that? Do I need to change my winamp visualization from milkdrop to something else?
    Third, when I go to that setting where I can change the color of the menu and then save them as day or night skin and then below it are buttons saying "switch to day or switch to night" nothing happens. I can pick a color and click save to day and when I click switch to day nothing changes. Likewise with night. No change anywhere.
    I'll mess with it more tomorrow. I was just stuck on these three things.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
