So he can add up all the "PROMISES" of donations! :lol: None of the calcs I've seen have a "%" key which i believe is indispensable; 50.00X15%=tip
Printable View
Congrats on the New release, you are Skin god !!!!!!!!!!!!!!!!!!:peace::peace: Cheers
Little problem with cyberlink power DVD 6.0 it use to work with 2.5, but in 3.0 there is now a a beige screen infront of the program and DVD skin buttons appear to be black.:violin:
Ok, not sure what the problem is with the beige window, but I do know the problem with the black buttons. The buttons are black due to a very technical and hard to explain phenomenon..... And that is...... I totally for got to skin it :D It will be corrected in the next release.
Hi,
I'm using Autoroute as navigation but I don't get it to launch in S&T skin. In RR I have configured it as external GPS and instead of writing Microsoft Street & Trips in the GPS windows name I'm writing "Microsoft AutoRoute"
If I launch the GPS for iguidance as is the default GPS I will get the new GPS windows and my Autoroute is starting in the window. But if I choose Street & Trips I will get up the S&T windows but my GPS software is not launching.
Can I edit any file to get it to start when I choose the S&T window?
Thanks for a really nice skin. If I will get everything working so I can use this great skin I will ofcourse donate some money for you.
Jonas
the streets and trips code is hard coded on the button. This way if you have iGuidance, Streets and trips and Map Point, you can have all 3 buttons to load them up, all running at the same time, without changing settings in the rr configuration.
If you open the exectbli.ini and search for "streets" you can see the path and window name. You can change them to your program path and window name.
Pretty cool skin - I'm not familiar with older versions but I'll most likely use this when my carPC is ready to go.
One question though - Under Weather/Live, how do I change the default location where it's zoomed to?? Everytime I move it to where I live and close RR, when I re-open it its always back over Florida. I looked around in .ini files for a possible setting but couldn't find one.
Thanks for your help.
It works after I changed the S&T launch path to my Autoroute path in execTBL file and changed window from Microsoft Street & Trips to Microsoft AutoRoute in the StreetStrips skin file.
I will donate some money for you after I have installed it in my car next week and tested it for some time.
Thanks again for a really nice and great skin :dance:
One other newbie question.
Is it any easy way to add a buttom to eject a CD in your skin. Maybe change the mute buttom to eject instead?
John, awesome skin, as we all knew it would be.
Question for you, is there anything in your skin or RR that could possibly cause issues in other front-ends' operation of XM and FM radio? I was using CF before your skin came out, and XM and FM (using Silabs radio) worked fine in CF. After installing RR and your skin yesterday, and playing with it today and yesterday, I went back into CF today for a little bit, and to get XM to work in CF, I had to reboot the pc, and I still can't get FM to work at all.
I can't see how your skin or RR would interfere, but I wanted to see if you had any ideas?
