Page 9 of 557 FirstFirst 1234567891011121314151617181959109509 ... LastLast
Results 81 to 90 of 5570
Thread: DigitalFX 4.0
  1. #81
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Enforcer View Post
    So he can add up all the donations, but wouldn't a normal calculator do that?
    So he can add up all the "PROMISES" of donations! None of the calcs I've seen have a "%" key which i believe is indispensable; 50.00X15%=tip
  2. #82
    Jan 2008
    Congrats on the New release, you are Skin god !!!!!!!!!!!!!!!!!! Cheers
    Little problem with cyberlink power DVD 6.0 it use to work with 2.5, but in 3.0 there is now a a beige screen infront of the program and DVD skin buttons appear to be black.
  3. #83
    Jun 2002
    Virginia
    Quote Originally Posted by treetop777 View Post
    It does have a decimal though (15%=.15).
  4. #84
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by itech View Post
    Ok, not sure what the problem is with the beige window, but I do know the problem with the black buttons. The buttons are black due to a very technical and hard to explain phenomenon..... And that is...... I totally for got to skin it It will be corrected in the next release.
    My Fiero Build Thread
  5. #85
    May 2005
    Stockholm
    Thumbs up Problem with S&T launch for autoroute
    Quote Originally Posted by JohnWPB View Post
    This was an oversight on my part, as I do not use S&T, I just overlooked it, sorry.
    Open the StreetsTrips.skin in the skin folder into notepad. Paste the following line at the header of the skin:
    INC,DFX_Font_Color.txt
    So the top 4 lines of the skin will look like:
    MEDIACAR Skin
    MEDIACAR MainMenu Skin
    StreetsTrips_OFF.png,StreetsTrips_OFF.png,StreetsT rips_ON.png,StreetsTrips_OFF.png
    I also corrected this for the next release.
    Hi,
    I'm using Autoroute as navigation but I don't get it to launch in S&T skin. In RR I have configured it as external GPS and instead of writing Microsoft Street & Trips in the GPS windows name I'm writing "Microsoft AutoRoute"
    If I launch the GPS for iguidance as is the default GPS I will get the new GPS windows and my Autoroute is starting in the window. But if I choose Street & Trips I will get up the S&T windows but my GPS software is not launching.
    Can I edit any file to get it to start when I choose the S&T window?
    Thanks for a really nice skin. If I will get everything working so I can use this great skin I will ofcourse donate some money for you.
    Jonas
  6. #86
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    the streets and trips code is hard coded on the button. This way if you have iGuidance, Streets and trips and Map Point, you can have all 3 buttons to load them up, all running at the same time, without changing settings in the rr configuration.
    If you open the exectbli.ini and search for "streets" you can see the path and window name. You can change them to your program path and window name.
  7. #87
    Mar 2007
    Atlanta, GA
    Pretty cool skin - I'm not familiar with older versions but I'll most likely use this when my carPC is ready to go.
    One question though - Under Weather/Live, how do I change the default location where it's zoomed to?? Everytime I move it to where I live and close RR, when I re-open it its always back over Florida. I looked around in .ini files for a possible setting but couldn't find one.
  8. #88
    May 2005
    Stockholm
    Thanks for your help.
    It works after I changed the S&T launch path to my Autoroute path in execTBL file and changed window from Microsoft Street & Trips to Microsoft AutoRoute in the StreetStrips skin file.
    I will donate some money for you after I have installed it in my car next week and tested it for some time.
    Thanks again for a really nice and great skin
  9. #89
    May 2005
    Stockholm
    Possible to add a eject buttom for CD?
    One other newbie question.
    Is it any easy way to add a buttom to eject a CD in your skin. Maybe change the mute buttom to eject instead?
  10. #90
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    John, awesome skin, as we all knew it would be.
    Question for you, is there anything in your skin or RR that could possibly cause issues in other front-ends' operation of XM and FM radio? I was using CF before your skin came out, and XM and FM (using Silabs radio) worked fine in CF. After installing RR and your skin yesterday, and playing with it today and yesterday, I went back into CF today for a little bit, and to get XM to work in CF, I had to reboot the pc, and I still can't get FM to work at all.
    I can't see how your skin or RR would interfere, but I wanted to see if you had any ideas?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
