Hi again.
I try all these days to find a solution about the 100% percentage when I enable the gps port in RR. The flash clock is enabled and RR never hangs. It only does when GPS port is other than 0.
So In the menu.ini I disabled these 2 lines because I don't need them. (In menu2.ini they are enabled and they don't affect what I will write).
L,1,0,1,1,0,0,0,12,"Arial","GPSHDG",
L,1,1,1,1,0,0,0,8,"Arial","GPSCompass",
So when I disable them RR don't start. If I enable these 2 lines RR starts normally. I try to figure out if these 2 lines affects the 100% load of the cpu when gps is enabled. But I can't delete them because RR don't sarts. Bingo. Any idea?
